Question about Canon Office Equipment & Supplies
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. But everything is plugged in properly. I just printed something, then one minute later when I went to print something else, it wouldn't let me! Please help!!
  • Canon Master
  • 19,396 Answers
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Posted on Sep 19, 2008
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
Error 306 can't get printer to work with my mac. It was working just fine until I changed the cartridges and now it gives me an error 306
Error 306 is a communication error and should have nothing to do with the cartridge. Check to make sure the printer is plugged in and restart your computer, and try again.
Jul 25, 2011 | Canon PIXMA MP620 All-In-One InkJet...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Error 306
    A communication error has occurred. reinstall drivers or change usb cable
    Mar 19, 2010 | Canon PIXMA MX310 All-In-One Printer
    Every time i try to print, the computer doesn't seem to see the printer and it stops the job. error message # 306. very aggravating!
    That error message usually means you have a communication error. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again
    If that doesn't work, try this:
    1. Start Home Applications, go to Utilities, select Utility Printer Setup
    2. Hold down the "option" key and click on "More Printers" button
    3. From the main menu, select "Advanced"
    4. In the next dialog box, under Device: select field "LPD / LPR Host or Printer"
    5. In the device of the "URL:" lpd://PCName/PrinterShareName
    6. Click the "Add
    If that doesn't work either, check your router settings.
    Mar 04, 2010 | Canon Pixma MP500 All-In-One InkJet...
    Can't print from my Apple Laptop.  Error message reads "306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try...
    frist u should check your printer port is install o r not in your computer . right mouse click on my computer then click onhardwere, then click
    port,if not stall there is yello sign. instail it.
    2/ if not work.re install softwere driver once a time.
    Jun 19, 2009 | Canon PIXMA MP620 All-In-One InkJet...
    Canon MX850 keeps saying Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your computer. Then try printing again. I...
    It is possible that your ink cartridge is damaged. Try using an old ink cartridge that worked before and try to print again.Even if the ink cartridge you are using is full of ink, when sensitive electrical components are damaged, it wouldn't work.
    You can also try using a different printer to rule out the possibility that your computer is the problem.
    Sep 06, 2008 | Computers & Internet
    Error messages: U150 + Ink tank errors have occured
    ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
    SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
    Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
    527 people viewed this question
    old marine
    old marine
