Question about Lexmark Office Equipment & Supplies
Screen keeps coming up stating that my printer does not have one of its cartridges installed.
  • Lexmark Master
  • 19,396 Answers
Try the following:
  • Remove cartridges.
  • Unplug printer power cord.
  • Plug back.
  • Reinstall cartridges.
If that did not work, try a new set of cartridges.
Posted on Sep 19, 2008
Printer stuck in a startup loop
1. Power on the printer
2. Remove the the ink cartridges from the printer
3. Unplug the power cable from the back of the printer (Do not power off the printer prior to unplugging the power cable).
4. Press and Hold the "6" and "#" on the number pad of the printer. While holding those two keys replug the power cable to the printer.
5. The printer should power on and give the message on the LCD "Install print cartridges". Install the cartridge and close the lid.
6. The printer should give the message on the LCD "Insert Black cartridge". Install the Black cartridge and close the lid.
7. The printer should give the message on the LCD "Used Black cartridge". Load a couple of plain paper in the paper tray and press the OK button. Keep pressing the OK button until the LCD says "Aligning print cartridges"
8. The printer will auto-align the cartridges and the printer should be in a ready state.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Nov 20, 2012 | HP Office Equipment & Supplies
Orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
Trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
May 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Printer keeps stating align cartridge
I had the same problem and found that the wire inside the printer cartridge had a broken tab that secures it to the ink cartridge case. It needs a whole new cartridge assembly.
Nov 07, 2008 | HP PSC 750 All-In-One InkJet Printer
Have installed print cartridges in my new printer but screen keeps coming up stating one cartridge is missing. When I print the alignment page it is all black.
either you have not removed the seal on the cartridge, or you need to reseat the cartridge. another possibility is you have a defective cartridge. replace the cartridge. last but not least you have a defective machine that if in fact is new should be covered under a manufacturers warranty. contact them for service. good luck.
Sep 19, 2008 | Lexmark Office Equipment & Supplies
New Ink Cartridge
hmmm...what is the original? BX20? The BC 21 E is a generic for more than one printer. and you may find instructions on doing this at the www.usacanon.com site, under support.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Canon MultiPASS C70 All-In-One InkJet...
All in one printer
Did you remove the pull strip from the new cartridge?
Apr 15, 2008 | HP LaserJet 3050 All-In-One Printer
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
