Question about Lexmark Office Equipment & Supplies
When you print in greyscale, do you only need black ink or both color and black?
  • Lexmark Expert
  • 141 Answers
For most ink based printers you will have to maintain both color and black for greyscale. if you were more specific on model i could be more clear. good luck.
Posted on Sep 19, 2008
billfox1966
  • 231 Answers
SOURCE: cant print in black and white when out of a color.
disregaurd any prior solutions in cleaning any contacts. that model doesnt have an electrical contact to clean. there are little magnets inside each color and black cartrige that work off a float mechanisim inside each one. when the levels get low the magnet indicates to the printer it is empty. unfortunately for you this stylis model as with all brother model printers wont work even if the color your setting up in the properties or settings feature are set to black and the black is full. its the companies way of forcing you into buying new ink. be aware though that my brother catriges cost 78.00 for the 3 color and one black set. i found these cartriges online through ebay but with one more additional black cartrige for a total of 5 not for ,for a total cost of 13.11 with free shipping. sounds too good to be true but for 13.00 it was worth a try. i have now purchased several 5 packs from them and couldnt be happiere.
Posted on Jul 10, 2009
  • 990 Answers
SOURCE: I do not want to buy color inks. greyscale printing is all i need
Hello Lisa; Your machine can't satisfy what you want, because this machine make for color purpose, therefor, if they run out any cartridge they don't work, same reason if you don't want color printer why don't buy black and white ?
Posted on Nov 22, 2009
  • 17 Answers
SOURCE: Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Posted on Feb 18, 2010
  • 540 Answers
SOURCE: Re Canon 2600 printer.I recently purchased a black
Please follow the instructions below from Cannon support page...
Setting the Ink Cartridge When printing, you can specify which ink cartridge to use. This is convenient if one of the ink cartridges becomes empty, you can continue printing by specifying the ink cartridge that still has ink. Note:
  • When the following settings are configured, Black Only is disabled. The color ink cartridge is used to print.
  • A type of paper other than Plain Paper is selected for Media Type on the Main tab.
  • Borderless Printing is checked on the Page Setup tab.
  • Canon recommends that you use the ink cartridges installed in the printer and not remove them until the ink runs out.
You can set the Ink Cartridge Settings from the Maintenance tab in the printer driver.
To access the printer driver from the application software, click here.
To access the printer driver from the Printers folder, click here.
Application Software -
Note: Depending on the application software, command names or menu names may vary and there may be more steps. For details, refer to the user's manual of the application software.
  1. Select the command you perform printing on the application software in use. In general, select 'Print' on the File menu to open the Print dialog box.
  2. Select your printer model name and click 'Preferences' (or 'Properties'). The printer driver setup window appears.
  3. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  4. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  5. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  6. Click 'OK' on the Ink Cartridge Settings window.
  7. Click 'OK' or the applicable button to print.
Printers Folder -
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
For Windows Vista
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
  • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  1. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  3. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  4. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  5. Click 'OK' on the Ink Cartridge Settings window.
  6. On the Printing Preferences window, click 'Apply'.
Posted on Mar 04, 2010
SOURCE: full of black ink & need to print black. other
I ran this process two months ago when the printer was 4 months in use.
Try running through the manual cleaning process for the print heads.
1-press ink
2-choose cleaning
3-choose ALL. If that doesnt work try cleaning BLACK only.
when the cleaning finishes the machine will go back to standby mode automatically.
see pg 172 in users manual under routine maint.
Posted on Jun 28, 2010
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
BROTHER P-TOUCH IS not printing
It is obvious it has a failed electronic component, since these are not repaired/exchanged except when they are under warranty best thing to do is just replace it.
Jan 09, 2017 | Brother Office Equipment & Supplies
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Colour cyan not printing
Did all of the packaging come off the toner successfullywhen first installing. Can you see cyan toner on the transfer roller? (Black roller on actusl cartridge)?
Dec 08, 2013 | Office Equipment & Supplies
How to clean ink absorber for canon mp237
First of all open the ink cartridge of your printer.
When the ink cartridge would move all the way over, then disconnect the power cord of your printer.
Now pull the frame of rubber from the printer and remove ink pads.
To clean ink pads you may place them in a bowl having warm water and start rubbing and squeezing them to clean it from ink.
After removal of ink, keep the pads separate for dry.
When the pads get dry completely, place them back in rubber frame.
Reinstall the rubber frame in your printer.
For deep guide and support refer to-
Canon Pixma Mp237 Manual
Oct 07, 2013 | Canon PIXMA MP230 Multifunction color...
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
