Question about Nakamichi SoundSpace 5 Shelf System
Wire antena (that came with SS5 system) causes a hum
The wire antena which came with the system (and instructions were to extend the wire for its entire length) causes a hum. If I turn the interphase that connects to the system, or move the wire itself, it increases or decreases the hum, but will not kill it. Has anyone else experienced that? I'd appreciate any tips; thanks very much.
It is assumed that the hum is coming down the aerial wire it self....The hum should be eliminated
dissappear if you remove the wire from its connector at the rear of the receiver.
If this is the case then reconnect the aerial and try to find a radio station to listen to..
When you find a station you will find the hum dissappears as follows:
When there is no station detected the receiver tweaks up its sensitivity via the Automatic Gain Control, (AGC) and when this happens any thing that is detected on the aerial is reproduced at the speakers and in your case its just a hum.
I have heard this event lots of times and mostly its scrackles or scratchs or other weird sounds which come down the aerial while the AGC is flat out at maximum..
The radio station transmits a sound "carrier" and within this carrier there is the music content.
The receiver detects the "carrier" when you tune to the radio station, and then it sets its receive
level to the setting made by the volume control and then lovely music is presented at the speakers..
So in fact your receiver is working as it should be ,.,,, no worries mate....
Now if the hum is still there when the music is there then you have a fault, but as you havent mentiond this aspect your receiver is in my view quite "normal".
Cheers For Now
From YUBEUT..
Posted on Sep 27, 2008
I have an ingersoll-rand ss5 that intermittenly hums and trips the breaker at start up. I replaced the check valve could a pressure switch cause this to happen?
Hope I can help you. When you say intermittently hums and trips from start-up. Is this when the receiver tank is empty, or up to pressure?
One of the first thing to try, you seem to have done, it is usually the check valve which can cause this.
The second thing to check would be the capacitor, but you say you have replaced the motor, was the motor AND the capacitor replaced at the same time?
By what you describe it does sound like a power problem, the pressure switch shouldn't be the cause of the humming. (The pressure switch simply tells it to switch on when the pressure is low, and to shut off when it is up to pressure)
Do you have any other power tools or equipment plugged into the same system? It may be that you might not have enough power to run all your machines?
Finally, do you have your compressor plugged into an extension lead? Vital power can be lost doing this, if so, and if you can, plug it straight into the power socket and try that.
Kind Regards
Carl
Oct 04, 2012 | Ingersoll Air Tools & Compressors
Wall timer for carport lights; motion sensor lights
Manual for the discontinued SS5 appears following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals-old.html#SS8
Most the timers at local box store are cheap replica brands. I recommend higher quality, such as Honeywell single-pole heavy duty programmable (or dawn-dusk) timer shown following link: requires Neutral wire
http://waterheatertimer.org/Programmable.html#honeywell
If you need the 3-way or do not have Neutral wire, then battery-operated Intermatic is best choice. Choose either 1 or 5 year warranty:
http://waterheatertimer.org/Programmable.html#st01
Jun 03, 2017 | Intermatic Hardware & Accessories
I am replacing an old SS5 timer with this new one (ST01C) to control two sconces in my dining room. My question relates to the wiring. My old timer has three leads. The new one has four. In the switch...
Open following link to see clear drawing and instructions for wiring ST01C timer.
Page also has EZ programming steps:
http://waterheatertimer.org/ST01C-program.html#ST01C
Red wire is capped.
Blue wire goes to Load (wire to sconces)
Black wire connects to Line wire (wire from breaker)
Green wire goes to ground.
If you are uncertain about Load and Line wires, just connect them either way, turn power ON, push on-off button, it lights don't come on, then reverse wires.
I have tested this timer, and information here is correct.
Don't forget to install CR2 battery, otherwise display will not show.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 01, 2011 | Intermatic Inc. ST01C Digital In-Wall...
The antena on my 2005 chev silverado broke off at the base. Is the stud removable or do I have to replace the whole base?
You will have to replace the whole base along with the antena wire that goes into the cab. ON the base you will need to remove the retaining nut. The base will fall into the fender well. You will need to find the antena wire with in the cab, disconnect and reove it with the base. When installing the new antena you will need to put the antena through the fender well and tighten the retaingin nut. Feed the wire back through the are where the old was and reconnect. Good Luck. Please rate.
Mar 08, 2010 | OEM Systems Car Audio & Video
I have hooked up my converter box but its not receiving any signal. do i need to buy a new antana? Or what could be the problem?
make sure u have the antena hooked to box and box hooked to tv, make sure antena wire is actually hooked to an antena if wire is coming out of the wall, otherwise u more than likely need a new antena, or box it's self is bad but if it turns on and u see somtin on the screen like make sure antena is hooked up then the box is probaly good
Nov 18, 2009 | Insignia Digital-to-Analog Converter for...
Hum form both speakers, and moving the speaker cable where it goes into the console starts/reduces/stops the hum. Any solutions out there? Is there a ground wire broken in the connector?
Had this problem for years with my much loved SS5. Only just now i decided to pull it out and fiddle with it some more and have the "humming problem" SOLVED. See description and PICTURES below
-remove the 2 small philips head screws from the speaker plug.
-first note which wires go where, i took a picture.
-take a small object to "lever" up the tiny plastic "fingers" that hold the plug wires in the plug housing, i used a small file, but you can try fine nosed tweezers.
-whilst doing this pull back at the wire at the same time to remove the metal terminal from plastic housing.
-repeat for the remaining wires.
i used small electrical snips to "pinch" the tiny metal plugs to make the connection tighter. I pinched it till there was almost no space between the contacts then re-insert wires till it clicks and it is then locked in place.
replace the housing with the 2 screws, and when you go to plug the speaker back in you will feel it is "tighter". No more humming at all!
-repeat for other speaker. The process of "pinching" may take some practice to get it to fit nice and snug around the connecting pins in the SS5 main unit.
Note; pinch from the bottom flat surface of the metal, and you will see the contact coming closer together. if you do it from the top, it will simply spring back open when you release the pressure.
hope this helps, this problem had me scratching my head for a long time, i even tried re-wiring the plug, when it was simply the metal pins in the housing!
Sep 22, 2009 | Nakamichi SoundSpace 5 Shelf System
1985 ZX300 power antena problem. When the radio is turned on the antena goes down and when it is shut off the antena goes up. Al factory parts, radio, antena and all switches. Any ideas what would cause...
im guessing the antenna has been replaced and wires were mixed up. take the rear panel off in the trunk to give access to the antenna motor and look at the wiring there should be 2 small wires and one larger black wire. the black wire is the reception wire the other two are the power wires. switch the positions on the two power wires. say wire A is in plug 1 and wire B is in plug 2. final position should be A in 2 and B in 1. that should take care of it. good luck
Jul 08, 2009 | 1985 Nissan 300ZX
Hum coming from speakers
Faulty wires/ connections are the usual cause of hums on speakers. Try checking if the wires are properly connected. If it still hums, try replacing the wires with a known good wire.
Nov 20, 2007 | Audio Players & Recorders
Icom vhf radio
i have the same unit. i get interferance from my depth finder wire touching the antena wire off the back of the radio. make sure that no wires are touching the antena wire.
Aug 12, 2007 | Icom M302 VHF Radio
Nakamichi SoundSpace 5 Shelf System Logo
286 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
