Toshiba Dummy Card
There is a slot on the right side of my Satellite laptop with a plastic piece that pulls out and says Dummy Card. I assumed it was an extra memory drive, but not so sure now. Can you tell me what it's for and what type card I would need to put in it??
  • Anonymous Jan 30, 2009
    I know, that in this slot i can read a micro SD card, but i don't know how???
    Problem Solver:
  • 12 Answers
Hi TCamille,
It looks as though you're referring to what's usually known as a pc card, or PCMCIA card. It's used for a variety of secondary peripherals, such as wireless internet or wireless broadband, extra usb ports, extra ethernet ports, and lots of other things. You may never need it, but there are some good uses if you look around.
You can read more here:
http://en.wikipedia.org/wiki/PC_card
And here you can see some of the types of cards available, as an example:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=pc+card&x=0&y=0
~Cactus
Posted on Sep 20, 2008
  • 781 Answers
It could be a slot for memory cards from cameras etc
Posted on Sep 19, 2008
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Can not gt my sd card into the slot do u need a spefic kind
Yes the type of card matters for the slot. If your pc/ laptop is newer and you have never used the slot, then more than likely the dummy plastic piece is still in it. This needs to be removed before you can insert any cards into it. Also, an SD card will only fit an SD slot, there are many other types of cards as well. If your card slot says that it will except SD, XD, miniSD, and so on.....then you can insert the SD card that you have.
Aug 27, 2011 | Computers & Internet
Port with rectangle symbol?
I think that you mean the "PC card slot". It's a slot for using with some kind of external accesories. For example some could use it for a firewire card slot, so that can connect a firewire on the laptop. Here is the left side of your laptop
In case you want here is the link for your laptop from Toshiba.
Don't hesitate to reply at this post for further help.
Feb 24, 2010 | Toshiba Satellite L15-S104 Notebook
What do you have to do to change the screen on my toshiba laptop
First You Need To Remove The 6 Screw Covers..(plastic Sticker Covers)... 2 are located at the bottom of the screen (on each side of the TOSHIBA logo)... The Other 4 are on the Sides of the Screen..(2 on each side)...
Then Unscrew the 6 Screws
THen You Need To Pry The Front plastic Bezel From The Back Panel...
Use a guitar pick or thin plastic card to pull bezel away... start from the top middle, insert plastic tool in between the black front bezel and the silver back panel, Pry outward at a 45% angle until you unsnap it...
Slide your Plastic tool around the outer edge unsnapping all the snaps, then Pull the front bezel away/set aside....
THen you will need to unscrew the Side Rail Screws and the 2 screws on the top of the side rail posts..THese Hold the Screen To The Inside....
Then Tip The Screen Forward From The Top -- Pull It Outward and Lie It Down Flat On THe Keyboard....You Now Need To Unplug The Display Ribbon Cable....
There's a Piece Of Tape that secures the Display Ribbon Cable Port To THe Screen... Pull The Tape Downward and use the rest to pull the cable away from the screen... Unplug the LCD Bulb cable from the power inverter now....(the Pink and White/Or Red and White)
Your Screen Is Now Detached and Fully Removed From The Laptop...
Dec 03, 2009 | Toshiba Satellite 2455-S305 Notebook
How do you install ram in a toshiba a105-s4344 laptop
I take it that you already have the correct RAM you need. Wiith that, power off your notebook, unplug it, turn it over and your will see the larg cover closer to the right of the notebook. Unscrew the screw to release the memory cover and place it to the side. Be carefull with static when handling your memory card, install the card into any open slot in your notebook. (The memory card will go in the slot at a 40 degree angle and then 'snap' down into place. Replace the memory cover (the large piece you took off at the begininig.) power up you notebook and the new memory should be registered and ready for use. Good Luck.
Feb 02, 2009 | Toshiba Satellite A105 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Sd slot
    there's a dummy card to put in there to avoid dust from going in. Just push it in and it will pop out like other device that uses sd card, ie, digital camera or mobile phone.
    Your rate is appreciated. Thanks!
    Dec 25, 2008 | Toshiba Satellite M115-S1061 Notebook
    I feel like an idiot - I can't find the SD card slot on my new Toshiba Satellite A205 laptop
    i,d suggest looking carefully around the top edge of the laptop base. your looking for a small slot, the size of a 50 pence piece. or a quarter dollar US.
    this could be by the left hand-side towards the screen ( as Is On sony Vaios ) If you need a user Manual, they have them @ 7Manuals. @ about $7.00 Or £3.50p UK.
    Payments via Pay-Pal Accepted.
    Hope This Helps Mike @ compurepair.
    Feb 25, 2008 | Toshiba Satellite A205-S4617 Notebook
    Televison & Video Logo
    2,254 people viewed this question
    Top Televison & Video Experts
