My computer everytime i try to start my computer it just beeps and displays a message on my monitor saying no signal ive tried it on several different monitors but the same thing keeps happening and i have no idea why
  • 141 Answers
Install a new graphics card onto the motherboard into one of the free slots. i prefer radeon cards for durability. if you need more detailed instructions on how to do this please post back! good luck.
Posted on Sep 20, 2008
The screens starts to blink.
You're probably correct, but it could be the video card is set to the wrong resolution for the monitor. You should check that first. Monitors usually just pry apart, but the force required and the hideous cracking sounds deter many amateur would-be monitor techs.
Mar 29, 2013 | Samsung T220 22" Widescreen LCD Monitor
My Monitor keeps going black
Sounds like you have something overheating in the screen pull the back cover and blow it out.
Jan 20, 2013 | HP 17 1740 DVI Rotating LCD Monitor w/USB...
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
Everytime i start up computer a sigal appears saying "no video input"
I'm assuming after a few minutes, it does get a signal from your computer and all works? It does take about 30s +/- 90s for a computer to generate an output video signal so if your monitor comes on first, before the computer can send a video signal, then you'll see that message. You should see the same message if you shut down your PC and leave the monitor on.
Aug 15, 2011 | Philips 170C4FS 17" LCD Monitor
HCM Monitor has no display. When monitor started it becomes on but no display.All the function LED Becomes on.
Try disconnecting the monitor from the video connection.
Disconnect the power source and allow to set for several minutes.
Plug in the power source only and see if you recv. a no signal message on screen.
If not, you most likely have a bad display board or back light problem.
If you do recv. the message, you have a problem with your video card.
Nov 28, 2009 | Acer AL1916W 19" LCD Monitor
Monitor screen begins as computer is booting up and then screen goes black. Message says there is no signal.
If the power light dims or changes color after the no signal message comes up, that means the monitor went to sleep.
While the monitor is plugged in and on and the computer is also on, Try unplugging the VGA cable from the monitor. wait 30 seconds and then plug it back in o see if the power button light comes back to normal color and the screen flashes on.
If not, then the monitor is not getting a signal from the computer.
If using a desktop computer,Try a different cord or try the monitor on another computer.
If using a laptop, you need to activate the laptop to use an external monitor. That can be done through the display settings, OR, most laptops have a shortcut key feature which usually involves pushing the Fn key and one of the F keys at the same time. The F key may say CRT/lcd or have a picture of a monitor and a screen.
If the power light does light back up and still no picture, There may be an internal issue on the monitor
Nov 17, 2009 | ViewSonic VG2230WM LCD Monitor
Monitor - no signal
it doesn't seem to be a monitor problem but a computer problem, is this a desktop or a laptop ? see if you can re-sit the display adapters.
Jun 03, 2009 | Tiny Computers B1996 19" CRT Monitor
Syncmaster 203B LCD not working with Vista 64
I would first recommend reseting the bios, if the monitor still is black then it may be a problem with the graphics card
Dec 16, 2008 | Samsung SyncMaster 203B LCD Monitor
When I boot my PC up I get a blank screen and a message saying no signal then the screen goes into standby mode
OK, it's gonna be one of these 3 things :
1. The cable linking your CPU to your monitor might not be properly plugged or has been damaged. You should hence ensure that the connection between the two devices has been properly done and that the cable’s state is fine.
2. You might be facing a problem with your monitor if the CPU makes a single beep error sound when you switch on the system. You can check whether the problem comes from your monitor by testing it on another CPU. If you still have “No Signal” error displayed including the error beep, I would strongly suggest you to try to get your monitor fixed by a competent technician or to get a new monitor.
3. If you receive several error beeps when starting the computer, this might be linked to a graphic card dysfunction. You can refer to the motherboard notice or check that the connection has been properly set
Dec 12, 2008 | Computers & Internet
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
