Question about Sony PlayStation Portable (PSP) Console
Psp internet HELP
Do you know the wpa for a psp if its a linksys router??
  • Anonymous Mar 25, 2009
    need WPA key
  • 66 Answers
The WPA key for a PSP is the same as the WPA key for any device you may have connected to your wireless router, e.g. a laptop. If you know the key to your router, then that is the same as the WPA key for your PSP. If it is not a secured password protected router, or if it is using another encryption algorithm, then use "no security" or "WEP" for your PSP's security settings.
Posted on Sep 26, 2008
When i play my game the pause menu continuelly turns on and off. whats the probleb
Posted on Sep 25, 2008
    Problem Solver:
  • 12 Answers
Its unique for every router, it should say it on the sticker on the bottom of the router, or in the settings menu on the router.
I got a SONY PSP and it said that it scans through my Linksys WRT54G2 wireless router, it also says i need a a WEP key or a WPA key to make it work. what is the WEP or WPA key?
WEp key is your wireless security key
You can open the router page with ip address 192.168.1.1
enter user name = leave blank
Password =ADMIN
Enter the router setup page
Click the wireless tab.
Go to wireless security tab and below the wireless type there will be security key.
That is your key.
Sep 04, 2011 | Linksys WRT54G2 Wireless Router
My psp always says connection has timed out check for wpa key
You would need to enter the WPA that is being used by your router. This is like a "password" of sorts that prevents other people from using your internet connection without your permission. Once you find out the WPA key (it should be in your router's configuration), you can either disable WPA on your router, or enter it into your PSP.
Feb 28, 2011 | Sony PlayStation Portable (PSP) Console
Im trying to get internet on my psp so i press scan , it finds something but then it says enter thw wpa key wich i don't know how do i find what my wpa key is.
When you set up your wireless router you get the key. You have to go into your router security settings to get your key again.
Jan 29, 2010 | Sony PlayStation Portable (PSP) Console
My Linksys BEFW11S4 Wireless-B Broadband Router? i cant connect in my internet and my PSP how can i do to connect it?
Set up an open wireless network or with WPA encryption. The PSP supports WEP/WPA but not WPA2 or Wireless G, it's a B device.
Also use a short passphrase and DHCP to lease IP Addresses.
Nov 03, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
I don't know the WPA TKIP key and I have a router my psp wont
The WPA key is the router wireless password the wpa key can be found on the router page that can be accessed by the computer
so we need to click on start go to run and type cmd nd click ok in the black window type ipconfig and press enter note down the default gateway now open up a internet explorer and in the address bar that is the www bar type the default gateway ()ike 192.168.1.1) now if it asks you for a user name and password then try these combinations user- admin pass - admin
user- admin pass- password
user- admin pass- (blank)
the router page will open up now go to wireless then wireless security and you can find the key over there
note down the wpa key and close the page now enter it in your psp
Aug 10, 2009 | Sony PlayStation Portable (PSP) Console
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Internet connection of psp
To connect to the internet on your PSP, you need a Wireless Router or Wireless Access Point. Once you have a wireless one, you should know the name of your router. That's what an SSID (Service Set Identifier) is.
Once you know this information you should be able to find your router on your PSP. Once you do you should have a password on your router so no one you don't know can use your internet. When adding a connection on your PSP you will also need to enter the password for your router. You can use WEP, WPA-PSK (TKIP) or WPA-PSK (AES). WPA-PSK (TKIP) or WPA-PSK (AES) have very high security and WEP has a lower security.
Once you have added your connection, just type an address and surf! Not all websites will load because some require too much memory.
Assuming you have Official SONY PSP Firmware, Update to the latest version by going to Settings>Network Update. Locate your router and use it as the network connection.
Download the needed files and update by going to Game>Memory Stick>PSP Update.
Once you finish Update, go to Network>Internet Radio>About Internet radio. It will take you to a website to download the files needed and will install to your Memory Stick.
To put music on your Memory Stick, the Music must be MP3, AAC, M4A or WMA format.
Open your memory stick on your computer by pluggin in a USB cable to your PSP and going to Network>USB Connection or you can put the memory stick in a card reader.
Once in the root of your memory stick, there should be a folder called "Music". Put your music in there or in one more folder inside that. Two folders inside of each other will not be playable.
Place videos in the "Video" folder on the root of your memory stick.
Videos need to be MP4 format. 368X208 Highest MPEG4 Codec, or 480X272 x264 or AVC codec.
Need a converter?
http://www.formatoz.com/
Its a free and very good converter. Try it
Reply if you need anything else.
Oct 09, 2008 | Sony PlayStation Portable (PSP) Console
Connection error for sony psp
Hi this is definately a Wifi Fault code. if your doing everything right on connection and the PSP throw the 80410A0B code, you may need a new Wifi card. it is the same card as the memory stick. When connecting wifi, the PSP will tell you if the connection has security turned on or not. If it is WEP or WPA or something like that, you need a passcode the access the internet.
Jan 28, 2008 | Sony PlayStation Portable (PSP) Console
Can't get connected to the internet!
you have to be sure your modem is wirless if it comes up in scan then your good maybe your modem doesnt need a wep key it all depends on your modem
Jan 01, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
124 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
