Question about Electrical Supplies
Generator pulsates when its running 12-KW natural gas
Generator pulsates during running and the lights in the house also. Also seems to be oil in the air cleaner area. I' have to shut it down after 10-12 hrs. to check the oil and most of the time add oil. The dip stick is really hard to read also is there a trick to being able to see the oil on the stick a litter eaiser.
  • Anonymous Dec 14, 2008
    I have the same problem with my dg6000! I was told the float was stuck in my carberator thats why i have gas in my oil?Any help would be appreciated!!!
  • Anonymous Mar 12, 2014
    The starter is bad on my older Dayton generator, model 4LM41. It's a 5 KW standby generator and has always been goo to me so I'd like to keep it going if possible. Does anyone know where to find parts for this, specifically a starter?
  • 169 Answers
You've described the symptoms of a dirty air cleaner, surging throttle (the pulsating), oil getting sucked up thru the breather into the intake (the why you have to add oil).
When you check/change the air cleaner you should also have a look at the spark plug, the dirty air cleaner forced the engine to burn some oil and that may have left junk on the plug.
To make it easier to read the oil level on a dipstick, try dipping the stick into a little water. When you draw it back out of the water the contrast between the oil covered part of the dipstick and the water covered part will be a little more obvious. Sometimes looking at the backside of the dipstick is better too.
Carl
Posted on Dec 03, 2008
Engine will turn over/crank but will not run
All internal combustion engines have the same requirements. They must have the correct air fuel mixture and source of ignition in order to run. Although I am unfamiliar with the system you have, the fact thst it will start without the air filter but won't with the air filter indicates that you either have a dirty air filter (you said yours was clean) or you have too much fuel entering the combustion chamber. Beyond that I would only be guessing the reason (air fuel mixture regulator, worn jet, wrong size jet, something else bocking air flow etc.)
Dec 26, 2012 | Generac Power Systems Generac 5525 20 Kw...
I'm planning to install a 20 kilowatt Kohler whole house generator. After super storm Sandy we lost power for 13 days and got by on a 4 KW generator having to find gasoline and feed it to the gene
Ok, First of all the gas line to the generator should be separate from the other appliances, so yes you have to run a separate 1" line from meter to generator. The closer the generator is to the meter the better. The pressure should be fine if you stick to this. Also you will probably need a bigger meter depending on what you have now. PSI or WC is not the same as BTU's...The meter size controls BTU's and the regulator controls WC. Without knowing what you have for each generally the meter size will need to be upgraded.
Dec 22, 2012 | Electrical Supplies
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
When we purchased our home in '04, it had a Dayton generator in the basement, model no. 3W056A, serial no. 55658 F83. It runs on natural gas, or so I've been told: It has never run since...
Let me make sure I read your post corerectly ... You have a Natural Gas operated generator hooked up in your basement? That's a train wreck waiting to happen! How is the exhaust vented out and how air tight is your basement? What keeps the carbon monoxide from reaching the rest of the house, when it's in operation?
Generators are a great back up. I have a 15 kw, that carries most of the house, plus 3 pumps during a power outage (Due to severe electrical storms, recently) we have had 2 power outages in 5 days. However, the National Building Code says "NO" to any type of generator being operated inside a residence or building of any type.
Without trying to sound critical, you need to rethink your plans of getting your generator running again. At least in your basement. Have it moved outside first and check with your local officials regarding clearances to any openings in the house. Or as you said "Just scrap it."
I sincerely hope this helps you make the right decision. Thanks for choosing FixYa.
Jul 27, 2011 | Dayton Heating & Cooling
Generator starts up and then cuts out after 7-10 seconds. The cut out appears to be from a "shut down" switch as opposed to carburetor oriented (it's natural gas).
I don't recall, does your generator have oil monitoring, did you say you checked the oil. If it's a protection shutdown there may actually be an oil change timer as well.
Jun 24, 2010 | Briggs & Stratton Standby Generator 12 Kw...
Overcrank error message
The 'overcrank' error simply means it tried to start but never actually started. It cranked for an extended period. Check the fuel and starting issues you would normally check to start the engine.
Mar 31, 2009 | Kohler 12 kW Emergency Power System -...
Electrical Supplies Logo
196 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
