Question about Sharp AL-1641CS Laser Digital Copier
Sharp al1340 copier won't copy
Just recently a light on the copier started blinking and the copier would not copy. The light blinking is a pyramid of dots. What does this mean and how do I fix it?
  • 141 Answers
Those dots mean toner, when they blink it's empty. replace the toner cartridge. open the front door and pull it out. pull the seal on the new toner and slide it in. shut the door. that was easy! Good Luck!
Posted on Sep 20, 2008
Sharp AL 1000 loud start up, Drum cartridge light solid, TD cartridge light blinking, printer wont do anything ???
I have AL1340 and had similar issue, The gears were grinding - open the door on Right Hand Side (Where you normally clear jams) and tighten the screws (gently). you might check other easily accessible locations along the paper path and do the same thing. Be sure that the path is clear, you could still have a jam in it causing gears to grind.
Mar 13, 2018 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
Warning light is ON for drum AL1340 does it have to be replaced or does it need cleaning?
This means that the default set meter count is due and sometimes the copier stops at this level if it is set so. Please check if the copies are coming out clean and clear as sometimes it may display drum sign with as low count as 5000 copies if set so whereas it can even reach 50,000 copies or higher. If okay , just do not replace it and concentrate on how to clear it. Key in this ( C Auto C Auto) in this order and enter (24 press copy key, enter 7 press copy key). This clears the drum sign and you are relieved.
Jan 27, 2011 | Sharp Office Equipment & Supplies
How do I reset the developer counter? My SF-2035 Sharp copier showed a blinking developer light and flashing 0. I installed new developer, but the blinking light continues. How do I stop it.
open front cover enter (C interrupt zero interrupt)led must go off ,then enter 25 then copy key 2 then close cover press copy,copier will work about 3 minutes ,when stops turn off then on
Feb 24, 2010 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp Al1340 copier/Printer drum light blinking I realize i need to change the drum but meanwhile i woould like to continue to use it for afew moore weeks. Is it possible. I need a drum change code to...
Enter C(key) Auto (key) C (key) Auto (key)  so the panel power off. Press number copiers 24 and press print key, press number copiers 07 and press print again. Click C (key)  4 times. Now lamp drum  light on with + 18000 copiers. Good Luck!
Jan 15, 2009 | Sharp AL 1631 Copier
Copier drum reset code
Hello sir; The simulation code for reset drum counter at this model is # 20 sub code07 if need more help let me know.
Jan 03, 2009 | Office Equipment & Supplies
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
Sharp AL-1641CS Laser Digital Copier Logo
105 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
