Question about Dell Inspiron 1000 Notebook
No audio i have no audio need to find out how to get it back
    Problem Solver:
  • 40 Answers
Get make and model of device. (if someone built it then find out the audio card type) then go to the makers website and go to the support section. From there search you model number and then find the audio drivers to install.
Posted on Sep 19, 2008
Cant get tv audio through receiver directly (without satallite, Game, DVD connection)
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
M G
Jan 03, 2013 | Onkyo TX-NR609
AUDIO LEADS
There should be one audio cable, Green.
goes into one of the green plugs behind the computer.
Oct 31, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Sir,asus k8v-mx mther board- audio is not working on windows 7. kindly suggest a solution
This could have several solutions. If it is an on-board audio, might need to get audio drivers from Asus. If it's a separate audio card, might need to get drivers from that maker's site. You can also go to MS Win7 support site and post the situation for a solution. One way to find out is to go to your Device Manager and uninstall the audio drivers (or roll back the divers in the device properties) and see if Windows will load them back or load the correct ones if the original ones were not compatible.
And if the on-board audio is not working, purchase a new PCI audio card and install it, load drivers and have audio!
Hope this helps,
James
May 14, 2011 | ASUS K8S-MX Motherboard
How do I use my Bose Subwoofer with a different receiver??
You can use Bose Sub woofer with any receiver. There is a set of "Audio Input" jacks on the back of the Bose. Connect the plugs on the one end of the audio cables to the "Audio Input" jacks on the back of the Bose.
Connect the plugs on the other end of the audio cable to an "Audio Out" jack on the receiver.
If the "Audio Out" jacks do not match with the plugs of the audio cable, then you need to use adapter or modify the audio cable.
In case "Audio Out" jacks are not provided on the receiver, you may take the audio output from headphone socket.
hope this will help you.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 21, 2010 | Bose Lifestyle 28 System
My monitors speakers are not working, does it need a audio cable
first check ur monitor if they are audio input at the back or at the side of ur monitor.if your monitor have audio input you need a audio cable connector.
Oct 04, 2010 | Princeton Digital Computers & Internet
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Audio problems
To use the integrated speakers on this monitor you will need the audio cable. Most monitors with built in speakers has a single cable with a green jack on both ends. It would plug into the audio jack on the back of your monitor and connect the monitor to your soundcard jack on the back of your pc. Cable should be able to be purchased at any electronics/computer store. Hope this helps.
Jul 08, 2009 | AOpen F75PS 17" Flat Panel LCD Monitor
No audio
You will only get stereo sound from that TV matched with that Coby instead of full surround sound, without purchasing additional equipment.
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | RCA Audio Players & Recorders
Can only get the dvd player to use the surrond system
This is going to be a bit tricky with this model, since either your Cable or Sat box will need a Digital Audio Out, and you will need to purchase a Digital Audio cable. If your sat box has a digital audio out, connect a digital audio cable from the sat box to the digital audio in on the back of the Samsung. Then connect a red and white AV composite cable from an available audio out on the back of the cable box to the "Aux In 2" on the back of the Samsung - this may only allow stereo sound, however.
Your absolute best bet (and the simplest connection) will depend on whether your TV has a SPDIF OUT or Digital Audio Out (they are roughly the same). If your TV has a Digital Audio out, connect a digital audio cable from the TV to the Digital Audio IN of the Samsung. Now you will get sound from any cable, sat, or any other type of box that is connected to your TV.
-Tha Mp3 Doctor
Dec 25, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Dell Inspiron 1000 Notebook Logo
20 people viewed this question
Alun Cox
