Question about Mitsubishi WS-55807 TV
Mitsubishi 55 inch Digital TV WS-55807
Timer lighht stays on. TV will not turn on. No picture, no audio. Please help
  • wilsontennis Sep 21, 2008
    timer light is flashing on front of the tv. cannot turn the tv on, power button will not work. Power outage and now the tv will not work. help
  • 927 Answers
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Posted on Sep 25, 2008
  • Terry Minter Sep 21, 2013
    I did as you had said, but my tv blinked 3 times for the first set of blinks & was followed by 5 more blinks .Any ideas.? Thanks Terry
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Mitsubishi ws 55807
Good Day;
It sounds like your TV is experiencing a CONVERGENCE CIRCUIT failure. YES, it is worth repairing, it's a great TV. The cost will be from $450.00 to $650.00; call an Authorized Service Center and have them give you an estimate B4 repair. Good luck, big IRISH. PS: It's Not An Easy repair to do your self.
Sep 08, 2008 | Mitsubishi WS-55807 TV
Mitsubishi ws- 55807 clicking sound
My tv was working fine until now 8-9-08, it would not come on. The timer light comes on and goes off immediately.
Jul 20, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubish WS-55807 HDTV 55" 1080
RGB picture guns ( CRT's ) are ok. Your set needs a common
convergence circuit overhaul requiring replacement of two IC's,
part # STK392-570. Usual cost about 400.00.........T.
Oct 31, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi WS-55807 TV Logo
659 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
