Question about Dishwashers
Dishwasher not working
My GE dishwasher isn't working right. It turns on, I can hear the motor running, it fills with water, but then it just sits in the bottom. The heating element is working, because it smells really hot. Is there anything simple I can do to fix this?
  • ejp9 Sep 19, 2008
    I'm not sure it's the timer, that actually seems to be going, it is ticking and the dial moves. Is there any way to confirm that this is the problem?
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to remove the motor of your Dishwasher
unscrew it make it dry and clean!!!!!
check everything use the tester to find lost of connect??
Posted on Sep 19, 2008
    Top Expert:
  • Dishwashers Master
  • 79,865 Answers
The timer has failed, that is not simple, unless you are good at appliance repair.
  • yadayada
    yadayada Sep 19, 2008
    There is a circuit board the timer is part of I believe, if the board is defective then the timer can work and nothing happens, some models the board and timer are one piece, call the manufacturer and give him the model number and serial number if required, he can provide with more detailed info on the part.
GE porscrubber dishwasher does not fill or drain. Coil is good 800 ohms. Motor is running and spray pump works if I put water in the dishwasher by hand. Timer motor works
Check the float that tells it whether to turn the water on or off on a fill cycle. Check the switch also. Its usually on a corner of the machine. - Great diagnostics!
Mar 16, 2018 | GE Dishwashers
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
My GE Potscrubber Dishwasher doesn't spray water when it is turned on. It has power.
If you turn it on and hear a slight hum after water fill the motor is locked from non use. You will need to remove bottom panel and with power off you will see the motor right in the middle near the front. This is called a side winder motor because of how it sits. There are some blades you can turn to unlock the motor. Once the motor breaks loose which you will be able to tell when it does, turn power back on and let run thru complete cycle with heat dry in the off position. GE are about the only ones out there that will do this and it is usually from lack of use. Hope this helps.
Feb 21, 2010 | GE Dishwashers
Dishwasher won't fill on start
Check the following to address this issue.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 18, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Thermador dishwasher DWU244, error code "F" does not run?
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
Feb 15, 2009 | Thermador DWU244 Dishwasher
Ge dishwasher hums but will not work. is a 1999 model,,seldom use
When you use your dishwasher so infrequently the water inside evaporates and allows the pump seal to dry out, so there is no longer the lubricating water there. You may be able to solve this by pouring a couple cups of hot (not bioling) water directly into the center of the lower wash arm (center spray tower) and letting it sit for several minutes.
If that does not work, you can take the bottom panel off and turn the fan blade on the motor by hand until if turns freely. (don't do this with power to the motor or you may have some nasty banged up fingers !)
To prevent this from happening in the future, keep some water in the dishwasher by poring a bit in every now and then, or by running a fill and pump cycle at least once a week or so. If you are away for extended periods, you can try adding RV antifreeze to the dishwasher while away.
Nov 16, 2008 | GE Dishwashers
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
