Question about Dryers
I need to know what wire goes where on my dryer I have repalced a 3 prong with a four prong and it does not hook up the same way. Thanks Linda
  • gerbasio Sep 20, 2008
    I did as you suggested . the middle white wire had two white wires and a medal strap I removed the medal strap and placed the white wire on top of the other white wires. I place the groud wire to the frame under where i remove the strap. I then pluged in the dryer and it will not turn on as if there is no power., did I do something wrong.
The two ( now three) middle white wires and metal strap just bonds the neutral to the frame.. Can you reinstall the metal ******** top of the three wires in the middle? You did not do anything wrong.. and are you sure th ebreaker is on for that receptacle and the door to the dryer is securely closed? Otherwise.. you've hooked it up correctly unless the receptacle on the wall was mis wired...
Let me know what happens after you reconfigure the three white wires and reinstall the metal bond strap and check the breaker... If none of that works. I am afraid you wil need to verify what is wired to what in your receptacle.. Forthat you will need a voltmeter or one of those inductive voltage probes... or a close friend that is an electrician..
Posted on Sep 20, 2008
  • 706 Answers
Hello Linda,
maybe I can help you get it wired up correctly. First off..the main difference betrween a 3 and 4 prong cord set is the addition of a Neutral Line. On the back of your dryer, you should see a pass thru ( where the origanal cord went into the dryer).. There should be some kind of strain relief ...cable clamp that will need to be loosened to remove the original 3 prong cord set. Once you loosen the cable clamp, open the access cover to the power terminal block on your dryer. Depending on the model, you should see a terminal block that has at least 3 wire terminals on it.. Red, White and Black. match up the end ( assumed the new cordset was preterminated with ring lugs) onto the corresponding terminals of the block ( Red to Red, White to White and Black to Black). Once that has been done, you shoud have one wire left over and it is probably Green..That wire is your safety ground and should be bonded to the frame of the dryer or if the dryer you have has a ground terminal.. hook it there. That should do it.. If i have confused you or you are unclear on any of this.. please specify the brand and model number of your dryer and I may be able to provide detailed pictures of this.. Otherwise.. hope this helps get you goin...
Regards
Posted on Sep 19, 2008
Switched chords on dryer from four prong to three prong when plugged in the top left prong sparked did i fry my dryer or is this fixable?
This is probably fixable as you probably hooked the cord up wrong and it arced and likely blew the breaker before much was damaged. The 3 prong cord has obviously, 3 wires. As long as you get the middle wire in the the cord hooked to the middle terminal on the dryer, the other two wires can go to each of the outside terminals, no matter which one goes where. Correct the cord and you will probably be in good shape.
Sep 16, 2010 | Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
I moved to a house with a three prong outlet for my Frigidare electric dryer, model number FER341AC0, that has a four prong cord. I bought a new three prong cord but there is no color coding on the dryer...
The three wire goes on the electrical block on the back of your dryer just like the cord is made. If you look at the cord, it's made flat (Most 3 wire cord are made flat, Some are not) The wire in the middle goes in the middle of the block. The two wires to the outside go to the outside of the block. It makes do difference which wire goes on which side as long as the outside wires go to the outside.
Please rate solution
Sep 06, 2009 | Frigidaire GLER642A Electric Dryer
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Install four prong plug kit
hi thanks for the question the green wire goes to the frame of the dryer other wires red to red white to white black to black thanks the appliance doc
Sep 15, 2008 | Kenmore 62872 Electric Dryer
Replacing plug
ok on a drier on your terminal block the center wire is neutral the other two are hot on a four prong cord the green or ground wire connects to the body of the drier if the dryer already has a green wire coneccted to the body of the dryer then take it loose and hook it to the neutral terminal of the dryer then hook the green wire or ground of the cord where it was if you need any more help let me know
Mar 30, 2008 | Amana NDE2330AY Electric Dryer
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
