Question about Panasonic Strada CN-NVD905U GPS Receiver
Parking Brake Bypass.
I had my CN-NVD905U professionally installed by GeekSquad/Best Buy.  I am very, very happy with the system, notwithstanding the high price tag to buy map updates, and the disabling of critical functionality unless the parking brake is set.  Unfortunately, GeekSquad would not do a bypass for me, so I'm left to my own devices for getting this done.
I have no interest in watching DVDs while I drive, but I find it utterly obnoxious that I can't make even minor changes or selections to my navigation while I'm driving in safe areas.
I have read on this forum and some others that one can simply "ground" the parking brake cable to bypass this safety "feature".
I have a few questions:
1.  I have heard that the Strada has built in speed monitors that will ensure functionality is disabled even if the parking brake cable has been grounded.  Is this true?
2.  Will grounding that cable have ANY other negative impact on the operation of the system, or my car?  If it will, I'm not against doing this, but if I'm going to go ahead and do so, I'd like to know what to expect--the good, the bad and the ugly.
3.  How do I do this?  I'm not a mechanic or an a/v engineer, so I'm hoping for some guidance on how to find the cable that needs to be grounded, and to what I need to ground it to.
Thank you, Dan
  • Dan T Sep 20, 2008
    Even the government hasn't intervened to mandate that vendors of navigation systems make these "safety locks" on their products.  And you surely well know, there is only one reason the system was designed this way.  That sole reason is so that Panasonic can mitigate any legal and insurance liability if someone crashes their car while using the navigation features.
    So yes, you're right, it's not the answer I'm looking for.  While I appreciate your taking the time to read and respond to my original question, I would appreciate a more direct response to the questions I posed, and let me decide what is safe operation and what is not.
    If you have details as to what specific kind of interference with the ECU one could plausibly expect, that would be a productive start.
    dt
    Thank you for the detailed response.  It doesn't sound promising, but I am curious because quite a few references on THIS site mention that it works fine when the parking brake cable is grounded as a bypass.
  • 6 Answers
All you have to do is find the cable that labeled side brake ( I believe it's green) and attach that to any metal part of your vehicle and it should by pass the safety feature.
Posted on Dec 22, 2008
    President:
  • 1,263 Answers
I would suggest not ground the cable because as you know that a signal will travel the path of least resistance. you could interfer with your ecm and that is a whole different set of problems that will cost you a ton of money to fix. there is a reason for the safety features. I know it's a real pain, but the devices were designed this way so that the liabilty issues would never come back to bite them. I know this is not what you want to hear, but please rate the solution anyway.......thanks
Posted on Sep 19, 2008
  • 1 more comment
  • Ronald Mueller
    Ronald Mueller Sep 20, 2008
    well i am a mechanic for a living and the sensors as far as speed are interfaced with the ecm. they cannot be circumvented for any reason. the navigation unit is piggybacked onto the ecm and uses the parameters of the speed sensor on the vehicle to send a signal to the unit. by basic fundementals trying to tamper with the ecm will not only effect the performance of the vehicle but the nav unit as well. as far as the geek squad is concerned they may know how to install a electronic device to a vehicle but they have no clue as to what a nav unit piggybacked to a ecm will do. the ecm runs everything your vehicle does. I can use a scan tool and change the settings of the sensors however i still can't circumvent the safety features in a nav unit. and there is no one who will either because it just can't be done. this is food for thought. don't be mislead by alot of what you might read on this. my purpose is you give you the best advice that is avaible. beware of so called experts that tell you that electonics can always be tampered with and then installed on a vehicle.one more thing the DOT and the Traffic Safety Board do have mandates as well as what the the URL(UnderWritersLabatoryhave stated when they approved the use of these units in passenger vehicles
  • Ronald Mueller
    it is unfortunate but there are quite a few experts here that are not experts they assume you will buy the solution hook line and sinker when in fact they have know idea on how to solve the problem. when you asked for a detailed response i gave it, usually the ones that won't are the ones to watch out for. do me a favor and rate my help to you it would be appreciated... thanks
  • Ronald Mueller
    what most people don't realize is that most models have a cable that operates the brake itself, however on the electronic side of it there is a micro switch that is activated when you press the pedal same as the brake pedal. you also have antilock brake modules to contend with. i have installed lock out valves for brakes on trucks that come equiped with aerial lifts. so i do know quite abit about what you can and cannot do with safety issues on vehicles. if there is anything you need help with as far as cars trucks or heavy equipment just let me know by clicking on my user tab.
There is no parking break wire on my panasonic indash how do i bypass it
http://service.us.panasonic.com/OPERMANPDF/CNNVD905U%20INSTALL.PDF
Looks like the cable named"Side Brake" (Bright Green)must be grounded at all times to get your dvd always working, hope this helps.
Nov 07, 2013 | Panasonic Strada Cn-nvd905u Dvd Cd...
Panasonic HDD CAR NAVIGATION SYSTEM CN-HDX-300
I got this Panasonic HDD CAR NAVIGATION SYSTEM CN-HDX-300 from a car bought in Japan, can I use to install Southern Africa maps?
Apr 02, 2012 | Panasonic Strada CN-NVD905U GPS Receiver
We were installing a panasonic strada cn-nvd905u it was working fine untill we disconnected the battery to install amps after we disconnected the battery it reseted the panasonic unit now its asking for a...
1-800-211-PANA (7262),
Monday-Friday 9 am-9 pm; Saturday-Sunday 10 am-7 pm, EST.
If you forgot the code, the unit is ussless without it and can only be changed if you know the code. Try the number above for more assistance.
Jan 25, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
Where can i buy a panasonic strada cn-nvd905u?
Hi
Its available from Amazon - see link
Or if you prefer not to buy online, you can put your details into the 'Find a service centre' section at this link to find a Panasonic agent near you that will stock these.
Thanks for using FixYa. If you find this helpful your rating is appreciated.
Jan 18, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
I also have a cn-nvd905u. I called panasonic and the treated me like a thief because I didnt buy it from a "authorized dealer". After running across a bunch of fake directions, I finally found the ones that work. the directions are:
you need to touch the screen right above and below the white box that says "input ID Code" in this order and I guarantee it will work.
Right up, left up, left down, left up, right up, left up
Enjoy
Apr 14, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Anyone disable the Parking Brake?
Yes, I did it to mine, Just ground it and it will always be *Parking Brake mode* and you can .... You know. :)
Dec 22, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Unable to access most functions....
Hi !! If you dont plug park brake and light switch, some options will be blank. Turn off power supply conect those plugs (im advice you to do not conect speed cable). Turn on them reset the unit.
P.S. The park brake cable can be conected with tre ground. This way you can watch dvd with the car in moviment...
Go to the panasonic web and download the last update for your unit !! http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Mobile-Navigation/model.CN-NVD905U
I hope it helps yous... sorry my english....
Nov 21, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Cannot access Address, POI, and Nearest POI.
Panasonic Strada CN-NVD905U GPS Receiver Logo
405 people viewed this question
Top Panasonic GPS Experts
Richard Foster
Richard Foster
Will Halftowaite
Are you a Panasonic GPS Expert? Answer questions, earn points and help others
