Question about Gateway FPD2275W LCD Monitor
No video input
I have a problem with my Philips LCD Monitor 22 Inch widescreen. It shows No Video Input on the screen although I have checked my cable is fine.. No loose cables and no bent pins also. After rebooting also same problem. Please assist. Thanks.
    Sergeant:
  • 300 Answers
1. check to see that the video source is set to a resolution and refresh rate that is supported by your LCD widescreen.
a recommended setting to start with is 640x480@60Hz PAL COMPOSITE SVIDEO standard.
the next setting to try is of course 800x600@60Hz
if the LCD screen supports greater resolutions and refresh rates feel free to try them.
I'm confident that this will FixYa!
Thank you for choosing FixYa!
Az.
Posted on Sep 19, 2008
Asus ve205n lcd does not come on
It's might not be communicating with PC video card. It should pick up the input port automatically, but make sure on monitor is set to correct input like VGA. You can try re-seating video card on PC. Also test with VGA if you are using HD like DVI or HDMI.
Aug 31, 2012 | ASUS Ve205n 20" Widescreen Lcd Monitor Vga...
No input signal message and screen goes black
Check your video cable going from your monitor to the pc. If your trying to use more than 1 monitor, is your video card capable of using more than 1? Are you using the mother board video card or a store bought one?
Jul 22, 2012 | HP W2338H 23-Inch Widescreen Monitor
The screen is showing "No
check input output pins of tv or try to scan
May 04, 2011 | LG.Philips LCD LP150X05A2 Monitor
Hi,I have a LCD monitor Philips 19 inch Black. From time tot time,appear one error... NO VIDEO INPUT , and then is made black and appear "Entering sleeping mode" . What I must do? Or for where...
Check that the Video cable (VGA or DVI) is not damaged, if you move it does the screen go on and off?
If not then the circuit board inside the screen is faulty and needs reparing
Apr 05, 2011 | Philips 170S4FG 17" LCD Monitor
I get a "input signal out of range" with windows nt. Is it my frequency or resolution settings and can I correct it?
well it is maybe the video cards fault. But you could try installing windows xp or newer or older video drivers
Sep 28, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
There is power but no image
These are the troubleshooting steps for No Image:
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
If that doesn't seem to help, you can see a copy of the User's Guide here: http://www.westinghousedigital.com/pdf/60_User_Manual.pdf
I hope that leads to some improvement for you..best of luck
Jan 03, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Monitor will not come on
Try reseting your your video card by pulling it out and putting it back. test themonitor to other PC, if it works. if it works from other PC then the VGA card might be the problem.
Dec 01, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
170c lcd screen saying no video input
hey i relise you had this problem a while back but i am having the same problem, may i ask how you resolved this problem?
regards
adam
Jun 11, 2008 | Philips 170C4FS 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
