HP photosmart C4280 printer -- The printer works fine when printing documents or printing scanned documents. However, when printing out of the copy mode it prints incredibly slowly. Is there an easy fix for this??
You can usually calibrate your printer. When you first get your printer you may have to run through tests. One of them is where you print out a sheet with multiple colours on it and you then scan it to calibrate the scanner.Scanning will rarely give a perfect representation of the actual photo or image but if you do calibrate it may solve your problems.
Install software that is twain compliant.
Maybe the HP bundle that came with the printer.
Also Paint Shop Pro,Adobe Acrobat.Photoshop etc.
Use the usb cable after the install of the HP drivers then you may change the default location of where scans are saved.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
hi
i had the exact same problem and i installed and un-installed
over and over again
and then it hit me !!!
why bother ??? , just download a 3rd party scanning software like "VueScan" or any other you find on google and it does the job !!
it's light, recognize the scanner (C4280) automatically and scan !!
