Question about Gestetner DSM 651 Copier
Error SC 541
Need to fix it by tomr. What should i do?
Error message SC541 pop up from printer screen...
  • Gestetner Expert
  • 1,326 Answers
Try this... Press the Yellow reset botton then the number "1" then "0" then "8", don't hold them down, just push each botton once. Then hold down the "Stop/Clear" botton till the display changes to service mode, then turn the main Power Switch OFF then back On and see if it warm up.... If it dose not warm up you may have a problem with the fixing unit.... Good Luck
Posted on Sep 20, 2008
Sc 541 in sp 100
Apr 28, 2015 | Office Equipment & Supplies
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
this was translated from Russian by Goggle it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Nov 07, 2014 | Office Equipment & Supplies
SC 541 is a fixing unit error, clean the thermistor and then reset the code by pressing clear(yellow) then 107 and hold stop(red) key for 5 to 10 seconds then the display change. now turn off the machine from main switch, wait for five second and then turn on the machine.
this will reset the SC541. in case if the problem exist change your thermistor and check the thermostat.
Oct 31, 2014 | Ricoh Aficio CL3500N Laser Printer
My aficio 1515 have a code SC541
sc 541 is a fusr error. please email me on so i can email you a procedure to reset the code.
Sep 28, 2010 | Ricoh Aficio 2015 Copier
Sc 541 en aficio 1075 , cambié la unidad de fusión completa pero sigue marcando el error despues de 20 copias
hello friend
SC541 indicates that you have a defective thermistor.
replace the two thermistor and run SC reset.
Feb 22, 2010 | Office Equipment & Supplies
Hi I have an Ricoh aficio CL7300 printer and it is displayin error message SC541 what does this mean and how do i Fix it
sc 541=Heating roller thermistor error (Fusing unit).
The thermistors could be dirty or damaged.
The fusing unit can be removed and inspected(without removing any screws)(Left door)(lower handle).
If you see any damage you might have to replace the unit(or only the part if u r lucky).
Feb 10, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Code 541
may be the was damaged
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error message
SC541: Fusing Thermistor Open
Fusing thermistor defective or out of position
Poor thermistor terminal connection
Poor connection in socle of fusing.
Sep 10, 2008 | Ricoh Aficio 450e Laser Printer
SC 541
Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer selece 2 engine go to sp5-810 and reset this.
-Carl, please let me know if this helps.
Jul 30, 2008 | Ricoh Aficio AP600N Laser Printer
Gestetner DSM 651 Copier Logo
285 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
