Picture doesnt cover the entire screen
My tv doesnt have a picture in the upper portion of the screen. Philips 27PT5445/39
    Problem Solver:
  • 7 Answers
The vertical deflection is faulty, pls send it to a nearby service centre.
Posted on Sep 20, 2008
Only have part of picture on phillips 50tv
Are you missing the top portion of the picture or the bottom portion of the picture? looking inside the TV will reveal two modules to the furthest left of the inside. These are the upper and lower Y buffer modules. Replace the top one if missing the top half of the picture or the bottom one if missing that segment. Usually you can find good used parts on Ebay. Or
PHILIPS 50PF9631D 37 BUFFER BOARDS LJ41 03883A LJ41 03882A
Apr 05, 2015 | Philips Televison & Video
It is 7x3cm big, and its like dark green with bright green lines. I can see underneath it my screen, but only if i look deep.
if you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Nov 08, 2012 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Vizio 55" Inconsistant Dark Screen
you have to open the back cover to check weather the screen back light need replacement. usually if the lamp is almost black in color it needs replacement. the backlight is covered with metal shield installed at the upper portion and lower portion of the panel of the tv.
Nov 01, 2012 | Vizio VF Televison & Video
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
My sanding 55 in rear projection tv has several hundred dots on the screen and getting worse each day. How can this be fixed?
u need to unplug tv, remove cover of upper back portion which is behind the screen. u will see a mirror fitted on inside of back cover clean both screen, mirror. u will also find on bottom side 3 picture tubes. clean them as well.
Aug 25, 2011 | Samsung Televison & Video
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
42PFL3603D/27 TV was dropped or hit and broke the tv screen upper righ corner. Tv works, has spiderweb look on screen
can't be fixed becase the entire panel is broken. it is cheaper to replace, because wit labor, parts, ect it would be to expensive
Jan 22, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Magnavox tr3272C103
Maybe the close caption has turn on.,by using your remote press the menu and find the close caption and turn it off .
Oct 03, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
