Question about Troy Bilt 5.5hp Self Propelled Mower
Model Series 860
I have a new Troy Bilt 860 Self Propelled mower. I has been squeeking and today the self propulsion stopped working, it is cutting and can be manually pushed. My nearest Repair centre is 25 miles away. It it obviously under warranty as I bought it at Lowes about 6 weeks ago. There are lots of Small engine repairers in the area. I noticed first time out level one had me nearly running. Earlier today level one was sluggish before it stopped altogether. Is it the belt? Is it the cable? Is it something worse?
Any Thoughts
John Elsegood
  • 4 more comments
  • Anonymous Sep 29, 2008
    squeeks like crazy
  • John Elsegood
    John Elsegood Oct 21, 2008
    Took it to repair shop that Lowe's recommended as it was under warranty.
    Technician said they had had 7 bad transmissions inside a week!
    I thought Troy Bilt was a good company to go with.
    Anyway it is still being worked on... its been nearly 3 weeks so I should get a call soon.
    Thanks again
  • John Elsegood
    John Elsegood Oct 29, 2008
    Thanks for message about Troybilt, it is still in repair shop awaiting Transmission which is on back order. At least with snow arriving I am not going to be mowing my lawn.
    Will make sure I don't buy MTD products in future.
    Thanks
  • John Elsegood
    John Elsegood Dec 05, 2008
    Machine still in shop awaiting new transmission.... luckily we are in the mountains and winter has set in.
    Sound like Troybilt have serious problems.
    Hope that the person with the squeek has a dealer within range.
    Hope your solution works it could save him months of waiting.
    John Elsegood
  • Anonymous Apr 17, 2009
    Mower will not self propel and has always made a strange noise.
  • dnmccrary Apr 29, 2009
    I also bought this mower from Lowes last year. From the get-go it squeaked, one front wheel kept coming loose from the frame, and oil slowly drips out the engine. No one in my area is interested in doing the warranty work on it... "I'm too busy to get to it..."
    This mower is a piece of #$!&! There is no belt adjustment. No Idler pulley. Nothing! And hard to work on!!! Just getting to the belt is a major overhaul. Don't buy! Or if you have just bought, take it back!
  • 48 Answers
Sounds like a bad tranny if this unit is under warentty DO NOT ATTEMPT REPAIR . if you attempt to repair this yourself you can void any warrenty
Posted on Oct 21, 2008
  • enginedoc Oct 28, 2008
    just a note on your comment about troy-built - mtd now owns troy built - the quality is gone - if you go to lowes central tractor etc and want to buy one of thier cub cadets or john deere etc look under the seat - you will see whom they are built by - MTD - the consumer doesnt even know - as far as im concerned this is false advertising
    Genius:
  • 1,061 Answers
LIFT FRONT WHEELS OFF GROUND WHILE RUNNING DO WHEEL SPIN ?YOU CAN ADJUST CABLE AT THE CLAMP ON LEFT SIDE HANDLE ABOUT HALF WAY DOWN.PULL DOWN TOWARDS ENGINE.SHUOLD PROPEL NOW IF NOT REPLACE BELT, ITS STREACHED NORMAL WEAR.RICHARDM69
Posted on Dec 05, 2008
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt self propelled mower
Cribrat 1;
Please don't be offended but are you sure you are putting it on the right way. A lot of the mowers out today have guards that prevent the belt from coming off the pulleys if there is a foreign object caught up when they are being used. These guards are actually post that are fastened to the chassis of the mower. Troy built is a top name mower so I'm sure their design is reliable. Sorry I can't be more specific.
Does the tension on the belt seem adequate? Is there a tension adjustment. (an idler pulley with an adjustment)?
Hope this helps Good Luck Loring Please give me a rating Thks
Oct 29, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
1,712 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
