Question about HP Photosmart C7180 All-In-One InkJet Printer
My printer has a new black ink cartridge but it will not print black.
Attempts to solve include:
* Cleaning print heads
* Followed restart steps
* Aligned print heads
* Restarted computer and printer
Any help will be greatly appreciated!
Thanks,
James
  • 3 more comments
  • Anonymous Oct 08, 2008
    My new black ink cartridge will not print any ink. PLEASE HELP!!!! I am running the printer with an Imac.
  • bytesized Oct 21, 2008
    have the same problem here, don't seem to be able to buy a new print head from anywhere.
  • dougnethel Oct 26, 2008
    I have the same problem, color works fine. No black.
  • jayb63 Jan 10, 2009
    Same problem with mine. Does anyone have a solution??
  • Anonymous Jan 15, 2009
    My 2 blues wont print...hp support told me hardware malfunction...send it in and upgrade to other printer... the problem...my printer is worth 300$ and they will trade up and give me only 50$ off another....
Trade the unit in with hp directly
Posted on Sep 26, 2008
HP Photosmart C7180 printer with clogged print head.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 30, 2012 | HP Photosmart C7180 All-In-One InkJet...
Replaced ink cartridges and now printer will not print black and sometime
Aug 24, 2012 | HP Photosmart C7180 All-in-one Printer Fax...
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
Is it possible to convert this printer so it only uses black ink and it operates without the color cartridges?
The Photosmart printers work in Thermal Inkjet printing technology. This require all cartridges to be present with ink for printer to work.
You may disable the color printing feature using the printer properties, even though the color cartridge will still be in use.
Only Laser jet printers can work with Black cartridge alone.
Regards
Riztech
If this solution is helpful,kindly vote 'thumbs up' and testimonial.
Dec 31, 2010 | HP Photosmart C7180 All-In-One InkJet...
Black ink not working
Print out a test print to see what comes out. If the printer is printing the black and colour blocks then the printer should be OK. If not then check the black and colour inks to make sure they are OK and remove each of the cartridges and reinstall them. Then run a full cleaning cycle and reprint the test sheet. Keep doing this until all the inks are printing OK. Then run an alignment test making sure that there is plain white paper in the paper tray and adjust the printer as necessary.
Oct 07, 2009 | HP Photosmart C7180 All-In-One InkJet...
Black ink cartridge not empty, but won't print black...
Try running the cleaning tool included with the HP diagnostic software for your model printer. If that doesn't work, try cleaning the ink jets on the black cartridge directly with an alcohol swab. If this still doesn't work and you're sure that you have the correct model HP cartridge installed properly in the printer, you may have to replace the black cartridge with a new one to see if the cartridge itself is defective.
Oct 02, 2017 | HP PhotoSmart C4480 All-in-One Printer ...
Hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
Feb 09, 2009 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
797 people viewed this question
Seeker5211
Seeker5211
