Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Macbook & Projectors
Hi: I'm having problems using multiple projectors with my MacBook. When it's connected to a new projector (other than my usual) it often won't display what's on my MacBook's screen. I have the video mirroring turned on and the screen resolutions match, but what seems to happen is that it's treating the projector like an extended desktop, even WITH the video mirroring on. For example - I was doing a powerpoint presentation, then wanted to launch a short video in my VLC player, in order to do that I had to drag the player to my right and drop it on the extended desktop. The cursor disappeared and it was all too embarrassing. Any suggestions on how to fix this. It doesn't happen with every projector - but two out of the last three were truly confounding. Thanks for any help you can provide.
    Scholar:
  • 38 Answers
Hi there
Yep, sounds like the machine thinks it is an additional monitor. So you can run it as that but the mirroring does not work. So the mirroring works with your own projector?
There are a couple of things you can do. Try connecting the projector and power it up when you machine is off and then boot your machine up. If the mirroring still does not work open up your display panel look under arrangement. You should then see two displays. One will have a red line around it. That is your laptop. In the display panel you can then drag the second display over your display and that should have the same effect as mirroring.
That's the low tech first try.
Posted on Sep 23, 2008
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
Sep 02, 2014 | Sanyo PLC-XU101 Projector
Need the driver for dlp projetor at-x51 macbook
Hi, You shouldn't need any drivers, it's a standard projector.
Connect the whole lot together then turn on the projector then turn on the Mac. if that doesn't work try it the other way around.
So far I have not had any problem with projectors (of any make) but there are times when the Mac doesn't recognise one at the first attempt.
Apr 05, 2013 | Apple MacBook Pro Notebook
What do I use to connect Macbook pro to an Epson EMP projector?
you need a cable:
type depends on your macbook pro model and epson:
use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-2.jpg use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-5.jpg use-connect-macbook-pro-epson-emp-rd53xsmc3ry4fozipcd12amw-5-9.jpg
Nov 29, 2012 | Epson EMP-S1H Projector
I have a MacBook Pro (latest edition) and can't sync it with my Data Projector ACER PD523 DLP
Are you connecting with VGA etc cable. It (your Mac) should automatically sync. Also check input on projector, there's usually multiple input options
Jan 04, 2011 | Acer PD523 Multimedia Projector
Macbook screen crashes when connected to projector
this is probably a projector setting
try checking the setting of both systems
May 09, 2010 | Apple MacBook Mac Notebook
Can i hook up a macbook to this projector?
sure can!
There are a few options. Check out the apple website for a list of adapters.
Your best bet, depending on what macbook you have, would be a mini-DVI (plugs in to your macbook) to a DVI (plugs into the projector computer input)
The adapters are quite cheap at around $15 adn this will make the projector work just like an extra monitor connected to your macbook
Good luck!!
Feb 20, 2010 | Hitachi CP-X1200 Multimedia Projector
Problem hooking my macbook to the Powerlite 62c/82c the projector
For these types of projectors if you're planning to hook it up using you MacBook ;
You will need a converter ( from VGA to DVI )
Using the VGA cable that came with the unit when purchased ;
Connect the VGA cable on the back of the Projector and on the other of the cable you will connect the converter ( VGA TO DVI ) since for MAC systems it has DVI ports for monitors not VGA...
You can purchase the converter at any Mac store or any computer shop near you..
Mar 13, 2009 | Epson PowerLite 62c Multimedia Projector
Can't use my hp sb21 with my Macbook
it works if you do it in bootcamp. but have to select external monitor instead of digital display under the intel graphics control panel. does anyone know of such an option under OSX?
Jun 13, 2008 | HP Digital Projector sb21 Multimedia...
Connecting a Projector to a MacBook
Hi there
You will have to find out if this Projector supports Mac
Mar 30, 2008 | Sharp XR-10X Multimedia Projector
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
768 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
