Question about Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018
Charger new charger
  • 3 more comments
  • ktakat Oct 03, 2008
    I moved and have yet to find the 2nd charger and the instruction booklet. I cannot remember how to charge the battery. Do you have instructions? There seems to be electric outlet prongs; they are visible but inside the battery.
    ktakat@aol.com
  • Anonymous Mar 12, 2009
    Broke (dropped) the charger. Called B&D and they want $45 + ship for a product that costs $99. Something is wrong. Anyone know of a less expensive place?
  • ktakat Mar 25, 2009
    Thank you for the information, mrfixit-jerr. I appreciate it.
  • Ellen Duran
    Ellen Duran Apr 17, 2009
    My trimmer stopped working. I keep it on charger but still doesn't work. The red light lights as if charging. I have taken battery pack off and put back on per instructions in troubleshooting guide. What next? Thanks!!
  • Paul Evans
    Paul Evans May 11, 2010
    What about it?
My computer no longer charges. I replaced the charger and for a little while the new charger was working. But now the new charger will be in the charger portal and the computer does not charge at all once...
this problem comes from a bad Battery.
you told:"I replaced the charger and for a little while the new charger was working"
it means that the battery is damaged and only because of a new charger, charged for a little time.
so change the battery.
Jan 17, 2011 | HP Mini 1035NR Notebook
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
Dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Nov 06, 2009 | Makita 18V LXT Lithium - Ion Cordless...
Have a Fire Storm place battery in charger green light comes meaning full charge but place in drill there is no charge. Is it a new battery, or new charger, or new drill required
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Oct 16, 2009 | Black & Decker 18 Volt Cordless Drill...
I cant charg my psp i cant find my charger
When you say you can't cahrge it, do you mean on your PC, PS3 or with the charger? I don't think the PS3 charges the PSP, I have no idea about the PC, but if the PSP doesn't charge using it's charger, it is either the battery, the charger, or the psp charger outlet. If it is the battery, buy a new one. If it is the charger outlet, it is a good idea to have 2 working batteries and to buy an external charger at game crazy, game stop, or from sony. This way, you can switch out batteries while playing, like me :). If it is the charger, buy a new one.
I would suggest first trying to buy a new battery. If it works, you are good to go and your old battery was broken, otherwise your charger/ charger outlet is broken. Buy an external charger. Then, you will be able to charge the batteries while one is in the PSP.
A new battery and an external charger cost about $70, but it is worth it. I hope i helped.
Sep 05, 2009 | Sony PlayStation Portable (PSP) Console
Need a new charger
Go to ebay.com and search for Samsung Digimax L830 charger. You should be able to buy a new one for around 18$ including shipping.
May 11, 2009 | Samsung Digimax L830 Digital Camera
Black & Decker Grasshog 12 Inch 18 Volt Cordless String Trimmer/Edger NST2018 Logo
88 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
