Kenmore Elite H3 Washer Model 44826 (Front Load) Control Unit Motor
Recently I had water in my basement and I think the bottom of my washer was in about 2 inches of water. Since it's dried out it gives me a F11 error. This happened once before and the control unit motor (or mother board - as the repair man called it) had to be replaced.
I tried disassembling the front of the washer so that I can easily reach in for the motor. I got hung up after removing the bottom panel and the next two screws for the top panel (with door). It appeared to be still attached at the top near the contol panel.
I've gone on line and printed out several diagrams but can seem to figure it out.....I'm sure it's something I'm just not seeing and I'm looking for some guidance.
Also, if you have any advise on replacing the Control Unit Motor, please let me know. Thanks.
    Genius:
  • 1,028 Answers
"mother bd " is acessed from top not bottom remove screws on rear of top panel control is on rear rail..motor control does not give problems that often f11 is communication problem between the 2 controls ck for wiring problem first (corrosion ) on plug and such if motor control was in water possible it could be bad pull control out unplug wires and look for signs of water
Posted on Sep 20, 2008
I have a Kenmore elite HE3T front load. It gets down to 6 min then stops and flashes between 06 and F, what can i do?
Kenmore 110 4996 Use And Care Manual Troubleshooting
  1. "F" Variables [other than FH and F02] (=Electrical Problem)
  2. Select STOP twice to cancel the cycle.
  3. Select DRAIN & SPIN if there is excessive water in the washer.
  4. Unplug the machine for thirty seconds to reset the Central Control Unit
  5. Re-select cycle and press START.
Feb 27, 2015 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
Where is the filter on the kenmore elite h3 washer
There is not a filter per say, but there is a coin catcher in the pump assembly. remove the bottom panel and it will be right in front.
Eric
Oct 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load
theres an error between the motor control board and the central control board,,meaning you might have lose connection,,or burnt,wire,,this i would let a technician look at,,,good luck
Jan 03, 2009 | Kenmore Elite 45986 Front Load Washer
H3 kenmore washer doesn't spin out enough water
romove the lower acess panel (three screws across the bottom of unit) afte rremoving you find the pump assy directly infront of you remove the large screwout filter im sure yull find all sorts of items in there. be aware when you unscrew cap water us in the hose above you will get wet! unplug unit too!
Nov 08, 2008 | Kenmore Elite 45986 Front Load Washer
Washer won't spin - HE2 Front End Load Washer Kenmore
Check the motor control unit. It is on the bottom in the front. It connects to the central control unit. You have to take the top off in order to access it.
Apr 19, 2008 | Kenmore 43142 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
F/DL means the door lock.  If you take the bottom panel off (there are 3 screws), you can reach up and pull down on a lever to release the lock.  Next you need to take off the top of the washer (there are 3 screw on the back).  ONce you have the panel removed, you can see the wires and where they plug in at the back right area.  If you just jiggle them, you can get it to work again.  I am doing this right now until I can get a new computer.  My neighbor has a front loading washer of a different brand and experienced the same problem I am having now.  She is the one who told me how to fix it.
Oct 12, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
315 people viewed this question
Top Washing Machines Experts
