Question about Yamaha RX-Z9 Receiver
Integrating 2 channel system with Yamaha RX Z9
I have spent many hour and hours trying to integrate my two channel system with my Yamaha RX Z9 receiver to form a 5.1 home theatre system. It is my goal to drive my front pair of B&W 802 speakers with my Classe CA 200 two channel amplifier and my Classe CP 35 preamplifier. I have two rear surround speakers, B&W 803, and a velodyne DD12 subwoofer. I have attempted to attach schematic diagram showing how the components are connected. However, I am not certain whether the image is attached. Accordingly, I will describe the system in detail assuming the image is not attached.
My Classe CA 200 amp has balanced connectors (XLR) to my pre-amp. My Classe CA 200 is connected to my B&W 802 speakers with bi-wired cables. What I mean by bi-wiring is that each cable has a single spade connector at the amp end but two spade connectors at the speaker end. One cable carries both (+) leads and the other cable carries both (-) leads.
I have also bi-wired my two rear surround speakers to the L and R Surround jacks on the back of the Yamaha receiver.
My center channel is bi-wired to my Yamaha to the Center jack.
I have connected my subwoofer to the Yamaha through a single coaxial cable to the subwoofer L jack.
Now for the tricky part. In accordance with page 27 of the Yamaha Owner's Manual, I have connected using coaxial cables with RCA connectors the RCA Line Out jacks of my preamplifier with the Power Amp In jack of the Yamaha receiver. Also, according to the instruction manual on page 27 and 84, I set Speakers B to Zone B. With this configuration I selected the tuner as the source and played music. Sound came from from the center channel speaker and the L and R surround speakers but not from the two front speakers.
I contacted another owner of a Yamaha RX Z9 and he recommended splitting each of my interconnect cables from my pre-amp to the Yamaha receiver. I was not certain where to make the connections so I took the two cable ends from the red jacks on my pre-ampl out line to the red jacks of the Power Amp In jack and the adjacent (to the left) Out jack. Similarly, I connected the two white ends coming from my white colored jack from my preamp to the two white jacks of the Power Amp In and Out jacks.
Then I conducted an Auto Set up. During the testing, test tones emitted from my center speaker, then my front left speaker, then my left surround and then my right surround. No sound emitted from my right front speaker. After completing the Auto Set up procedure I attempted to play music using the Tuner as the source. Again, no music came from either of my front two speakers.
Any help would be greately appreciated.
SOURCE: Vocals missing while playing with 2 speakers
Go to the amp "Basic Setup" and alter basic setup according to
- the size of the room (details in the manual)
- alter the no. of channels e.g. if you have only 2 front speakers, change the channels to 2.1 (.1 for the subwoof)
- Once the setup is changed, the amp pumps in sound according to the set up
All the best
Posted on Apr 29, 2008
SOURCE: no zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Posted on Mar 08, 2009
SOURCE: yamaha rx-v1600. I am failing in my attempt to get
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Posted on Aug 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a RX-V1000 Yamaha
Any Tape Out (REC) is flat Line Level output for any analog source selected by the RX-V1000.
Or you could just set up Zone 2 as on Page 61 in the manual - with or without the remote capability.
Posted on Sep 13, 2011
My yamaha rx-z9 receiver keeps turning off by itself. can you help
Did you ever get the problem fixed? I have same problem.
erikjohn@hotmail.com
Oct 13, 2009 | Yamaha RX-Z9 Receiver
Problem is starting Auto Setup on my Yamaha rx-v463 receiver
You need to press the AMP button before you press the ENTER button. Always press AMP first when selecting menu, enter, any surround mode, or one of the amp functions in ORANGE above the green numeric buttons.
Got this from Yamaha.
BG
Jan 26, 2009 | Yamaha RX-V463 Receiver
Yahmaha rxz9 no output signal to sub
the part where you plug in the sub has blown or warn out over night dude get it repaired i think u need to change the fuse inside the reciever
Dec 31, 2008 | Yamaha RX-Z9 Receiver
Yamaha RX-V663 wont play rear surround
The best way to get Dolby sound working is to connect the components using the optical links.
As long as you are using PCM the Dolby sounds will never get to your system. It's switching the Dolby sound off as soon as it detects PCM. I think the only way you will get Dolby on is via a optical cable which should let you have bitstream.
Mar 12, 2017 | Audio Players & Recorders
Yamaha RX Z9 and two-channel system integration
The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
Feb 26, 2017 | Televison & Video
Yamaha rx-v2200 sound problem
Hi Zanthena - my Yamaha rx v 2200 is doing exactly the same thing - did you manage to track the problem down? I have had my unit in for repair and the fault occurred again 6 hours after I re-installed it.
Any help would really be appreciated!
Jason.
Sep 07, 2008 | Yamaha RX-V2200 Receiver
Yamaha rx-z9 can not get digital audio
If your receiver is saying you only have analog, it must not be able to see the optical input. Check your optical cable, maybe it is damaged or not tight.
Dec 09, 2007 | Yamaha RX-Z9 Receiver
Problem: I am trying to Hook up my RX-Z9 and get sound out of MAIN.
Try pressing "Main A" or "Speakers A"-button on the remote-control (slide the shield at the bottom)
Nov 14, 2007 | Yamaha RX-Z9 Receiver
Zone 2 issues
Zone 2 only plays anolog inputs.
Aug 27, 2007 | Yamaha RX-Z9 Receiver
Yamaha RX-Z9 Receiver Logo
172 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
