Question about Dell Inspiron 710m Notebook
Cd/dvd drive I recently tried to burn a cd using my notebook but my drive wont open up, it makes clicking sounds as if its trying to open but nothing happens. Is there any way to force it open without breaking it?
  • 41 Answers
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Posted on Oct 02, 2008
Create boot disk
Insert a blank diskette into the floppy drive. Click start click on computer you should see all of you drives.
Right-click on Drive A. You will see the option to format the drive.
Click on Format. Depending on your operating system, you will see an option that reads either "Create a system disk" or "Create a MS Dos system disk." Click the box next to this option.
Click the "Start" button to begin formatting the disk.
When completed, you will have a bootable floppy disk.
For CD Rom or DVD disks
Open the software that you use to burn or write files to the CD-rom or DVD drive.
Click on "Make a Data CD or DVD." Insert a blank CD-R or DVD-R disk into the drive.
Look for the option to "Make this disk bootable." You may have to scroll over the various icons displayed to find this option. Click on the option.
Burn the CD or DVD as usual. Once completed, this disk can be used to boot your computer.
hope this helps
Aug 22, 2012 | Seagate Computers & Internet
Device name-HL-DT-ST-DVD-RAM-GSA-H55N it reads all cds, burn cd and dvd, reads dvds which are burned by me or other people but not company burned or movies which i buy. it was reading dvds also properly...
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
as for your computer hanging after it crashes
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on restart then defragment your hard drive
hope this helps
Mar 14, 2011 | LG SecurDisc 20x Internal Double-Layer DVD...
Cannot play cd/dvd's computer sees device but wont play. Try's to read a few times then nothing.
it sounds like you need a new dvd rom,
the drive that shows up in my computer can still be seen,
as you click on it , try to notice the sound of the rom,
sometimes you can use rubbing alcohol on the eye, or a cd cleaner can get it back
Apr 03, 2010 | Acer Aspire 6920-6422 Notebook
My MATSHITA BD-CMB UJ-120 wont read burnt CD ,DVD
yes,you need to change a new uj-120 or repair it.
http://www.it-battery.com/new-panasonic-uj120-bluray-bdrom8x-dvdâ±rw-ide-notebook-drive-p-1747.html
Feb 11, 2010 | Panasonic Computers & Internet
My dvd drive seems working. but It can't burn dvd and it can't play cd. Please help
Try blowing it out with a can of compressed air for computers. It sounds like the optical eye inside is dirty.
Sep 01, 2009 | Computers & Internet
Acer Aspire 5100-3583 dvd-ram wo't burn to dvd
sounds like your cdrw is shot need to change it >
Apr 22, 2008 | Acer Aspire 5100 Notebook
Dvd combo
Did you try axcessing the drive manually ??? Start > My computer > D:(you cd drive),, If it doesnt show up then the drive may be damamged. If it does you just need to associate the .ext with a program. Double click on the drive if a option box doesnt open up, you should see the audio files.. just right click on one and select properties. You should see the program the file is associated with. Just click change and select another program.
Dec 02, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Dell Inspiron 710m Notebook Logo
145 people viewed this question
Alun Cox
