Question about Samsung SGH-t629 Cellular Phone
Samasung shg-l810v hi could you tell me if there are 2 screws i need to to undo under the cover that protects the camera/ flashi need to get the the board to check my ribbon i have removed all screws (the eye can see ) but wen i try to lift the cover over the camera it looks like its going to break/shatter ??? any help would be a appriecated thanks roy
Bought a new power switch, how much dismantling do I have to do? It's driving me crazy trying to get the cover off the bar at the bottom of the screen. Help
Click on the link below for a detailed guide with pictures on how to remove the keyboard bezel. The guide is to remove the keyboard but you have to take off the keyboard bezel first. Its not your model but I believe it could work for yours. Check under the battery for any additional screws that maybe holding it in place.
http://www.insidemylaptop.com/remove-keyboard-from-gateway-mt6704-model-ma7/
Good luck.
Jan 05, 2011 | Gateway NV5215u Notebook
Can you please tell me the samasung deigital camera authorised service centre address in dilsukh nagar,hyderabad or anywhere in hyd?
http://hyderabad.justdial.com/camera-digital-repair-and-service-samsung_Hyderabad.html...........go to this link.............
Mar 22, 2010 | Samsung SCH-2500 Cellular Phone
Blower motor location
Hi, I had to replace mine also. It's located under the glove compartment, passenger side. Pull off the chrome moulding around the glove box and undo the screws. This will allow you access to the blower motor cover. Be careful of the light inside the glove box. You have to ubdo it's screw and feed it through the back. Undo the cover to expose the blower motor. You can also replace the interior filter in the same area if you haven't done so yet. Two screws on a narrow cover.
Good luck.
Norm
Jan 05, 2010 | 2004 Porsche Cayenne
How do you get underneath the keyboard
You don't need to remove the keyboard to access the ram. Just undo the single crosshead screw on the removable cover in the middle of the laptop from beneath. I you do ever need to remove the keyboard there are 2 screws underneath this cover, which are marked with a keyboard symbol. Undo these and then slide the 4 small lugs at the top of the keyboard and it will lift up
Jan 04, 2010 | HP Compaq nx6325 Notebook
How do you change a rear signal bulb in a 1990 toyota celica?
hi ders a plastic cap on the top of your rear light when u open the boot door,take out the screw under it and pop the cover off the orange piece on the side n unscrew the bolt..carefuly...it should just pop off then
Jun 20, 2009 | 1990 Toyota Celica
My Samasung NV3 is not charging and not swtiching on.
My suggestion is to open the battery door on your camera and remove the battery for 60 seconds. Then put the battery back in and close the battery door. Then try charging it and powering it on
May 30, 2009 | Samsung NV3 Digital Camera
How do you replace the lcd screen on A LG shine KE970
Take off the back plate that houses the battery, undo the four screws, then look where the bottom of the battery is just below are two cover caps remove and undo the two screws below now separate the cover. There is a circuit board under neath the panel unplug may seem tight but go careful, underneath this there are a futher six screws undo these and the two halves of the phone will separate. Now undo all the screws you can see here including the two that are under the two covers at the top they look like moulding marks separate the halves, undo the screws on the roller switch,lift this and you will find a ribbon connector that appears to be glued it's not, go careful and separate. Congratulations you have now removed the LCD. All you have to do now is remember which screw goes where and reverse the whole process. Good luck.
Feb 08, 2009 | Cell Phones
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
May 07, 2007 | Samsung RS2630SH Side by Side Refrigerator
Digimax i6 pmp SHUTTER problems!!!
Congratulations on fixing the problem! However I just wanted to let you and everyone else who reads this solution know that the part which failed on your camera is not actually the shutter. The shutter is deep inside the lens assembly right next to the image sensor. What you were dealing with was simply a protective cover for the lens. David Millier Advance Camera Repair
Feb 03, 2007 | Samsung Digimax i6 PMP Digital Camera
Samsung SGH-t629 Cellular Phone Logo
215 people viewed this question
Top Samsung Cell Phones Experts
kenneth njonjo
Mike Cairns
Mike Cairns
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
