Sharp TV 21" screen with a switch mode power supply.
Plse help as i have a power transistor(2sc5299) as switch connecting to the primary of an auto transformer and being driven by another transistor ( c3807 ) also being fed by another transistor (2sb 764)..... thus diag below
optical coupler N502 ----> B764(AF Driver) ----> C3807(hi-gain amp switch) ----> 2sc5299 ( large transistor switch ) connecting to the auto transformer.
Problem ..... the fuse keeps blowing and when checked i found that the
2sc5299 and the c3807 were gone( faulty) i checked the doides(rectifiers) and all are good. Plse explani why fuse and both transistors were blown as i have found replacement but no schema to this TV. Thanks for your prompt response as i await your findings. I have to complete this task. and i need your help ..... brgds Davies
    Problem Solver:
  • 7 Answers
I have a tv receiver with a problem of no power going to the whole system thiis transistor c3807 and connected to bigger transistor c4458 are gone together with connecting diodes.any solution please?
Posted on Jul 30, 2009
I have the same problem i need help with The values of resistors R517 + R523 + R515
Posted on Apr 28, 2010
Dear friend i read your problm i think the transtr c5299 you fixed that not original becouse you can fix the following trstrs bu 508af,d2498,bu2520,c4460,d5148etc... some times c3807 is not orginal,you use,d882,c2229,c2482,after these things the same is repeat you must have to change disc capacitors on base and collector of c3807,
Posted on Sep 30, 2009
I HAVE SHARP COMPANY 21 INCHES CRT MY FRIEND TV SET PROBLEM IS SET DEAD IN POWER SUPPLAY TRANSISTER 1886 REPLACED AFTER POWER SUPPLAY IS OK FBT ARCKING THEN IMMEDIATLY SET SWITCH OFF SET IN CIRCUIT R6
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 21, 2014 | Sharp Televison & Video
Wont turn on
seems like a power issue.
u should have the power checked out on the tv
Oct 02, 2008 | Sharp LC-32D4U 32 in. HD-Ready LCD...
NO POWER SHAHP TV
Check power cord, power switch button,fuse, fusible resistors, power regulators, rectifying diodes, filter capacitor. check also Horizontal output transistor.
Jul 08, 2014 | Sharp 21B-S10 21" TV
My Sharp TV's Stand-by Mode (Red), Model 14V-K80M, turns ON, turns GREEN when the other button is pressed but turns back to RED after a few seconds.
Hi
Your tv set may have an overload in the supply line. Check its rectifier diode and filter capacitor. Another approach is to check if the DC supply line of the switch mode controller IC (UC4842 for exemple).is present (10/12V). If these are OK, replace the switching MOSFET transistor and check the source resitor for open circuit.
Sully
Sep 21, 2013 | Sharp 27H-S60 TV
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
Hi,i just change the flyback of my sony KV-21JSR1 ,but still it's not working,it has sound(audio volume is working)but no raster,the flyback that i bought is only generic,because originals are not...
Hello
Have you a digital multimter that can count frequency. if so the testing will be easier to you. Just count the requency at the collector point of horizontal driver transistor, or at the base of horizontal output transistor. it should come around 15.625KHz [15625Hz]. When the tv wors with no signal this frequency may differ, but come very near to it. When it synchronises with a picture, it won't vary and will remain constant.
If you have no frequency counter, just measure the voltage at the collector of horizontal driver transistor. It will be normally connected to the primary winding of the line drive transformer, which is very small transformer on the PCB. Then check the voltage at the other end of that trnsformer, where supply to the collector of the above said trasistor is given. The voltage at the collector side of the winding and at the other side of the winding must have some difference, if the frequency said above is present, and drive transistor is working.
If there is no voltage, check the resistor connected to that winding to main power supply for open, or the capacitor fitted to that point to negative for short,,, or check the continuity of the driver trasformer primary winding itself, or a short between its primary and secondary windings.
If all of there are ok, and still LOT doesn't works, check the supply voltage to lot. Being a 21" TV, its LOT supply voltage comes upto 125VDC or so. If it is also there, try replacing the horizontal output transistor. It also doesn't help, the Line Output Transformer you have replaced is not the exact match. Sony EHT transformers are critical in construction and in winding. Keep it in mind, and buy an another. If you need any assistance freom me, don't hesitate, ask me through Fixya. OK.
Nov 05, 2010 | Sony Televison & Video
BLOWING FUSE , THE IX1791CE IS SHORTED
mostly this problem cause opto coupler is short. change the opto coupler and related parts like transistors,zener diode.and check all diodes&capacitors is power supply. you find any leaky or damaged part change it.
thank you
Sep 03, 2010 | Sharp 21B-S10 21" TV
NO PICTURE
the tv is fault, there is a lekage to ground, cause 5 amps is avery high current. plse take your tv to a w/shop and have the following checked
i rectifier diodes
ii power transistor, driver transistors, diodes, zener diodes
iii fusable resistors near the power transistor
iv making sure that a 90-110volts is getting out of the power supply to a line transistor, near the line trasformer.
the problem will be over
Mar 23, 2009 | Toshiba CZ32V51 32" TV
Televison & Video Logo
722 people viewed this question
Top Televison & Video Experts
