Question about Century Portable Plasma Cutter 25 Amp
Wont arc WHEN I HIT THE TRIGGER I GET LITTLE ARC TO NO ARC?
If you have water in the system, bad tip or ground it wont spark properly
Domo
Posted on Nov 10, 2008
Uniplas 30 power light flashing
See if the torch electrodes MIGHT be stuck... welded together. They have to arc and then separate or unit will shut down.
Jun 15, 2012 | Welding Tools
Pilot arc is highely spreaded
change the cutting nozzle
Mar 23, 2012 | Hobart Welding Tools
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
Spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Mar 04, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Once in a while when I strike an arc with the pedal, the arc starts at full amperage (even if it's turned down)and blows a hole in the material. Sometimes, afterwards "HLP" flashes on the display.
What does it do using the gun trigger and not the pedal? Peadal is supplied with full voltage and a reostat in the pedal is what regulates as you press or release. If machine is controlable without the pedal, The pedal reostat is kaput.
Oct 25, 2009 | Welding Tools
No arc. Power and Air OK
if the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
May 13, 2009 | Welding Tools
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Century Portable Plasma Cutter 25 Amp Logo
371 people viewed this question
Top Century Welding Tools Experts
John Trevino
Ted Maxwell
EugenesDIYDen
EugenesDIYDen
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
