Cd rom drive not working and showing error - Computers & Internet
  • Anonymous Mar 24, 2009
    no CD rom drive appears in my device manageer.
    What happened to it?
    It was there for years , now when I put in a disc-no mucis no images.
    Help?
  • 177 Answers
Under Device manager find your CD Romdrive. Red marks not enabled.Yellow Marks driver error.In either case do the following.Enable,Update Driver.
Posted on Sep 19, 2008
2 Suggested Answers
hothawk
  • 174 Answers
SOURCE: cd/rom drive door will not
take a long pin or straigten paper clip and find a hole infront on the drive insert it and gently push it till open.
Take care sometimes u see cd disc spin while it come out dont touch it until it stop
Posted on Sep 29, 2008
MY , CD/DVD LAPTOP DRIVER DOESN'T WORK. IT CAN
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell Computers & Internet
When i connect my samsung CD ROM drive (CD-RW/DVD DRIVE SM-332) hard disk doesn't work and it shows an error hard disk drive Emmett failure.but when i disconnect my samsung CD ROM drive (CD-RW/DVD DRIVE...
You will have to chnage the Boot Priority
Go to BOIS setup coniguration option by hiting F2 , F12 or Del key when staring the system
Change the priority to CD ROM as first priority and insert the Windows Disk and reboot the system to Run the Win XP setup
Aug 01, 2010 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
4600c not operating system error message bootmanager missing
You might have to go to the BIOS of your computer to ensure your drive is recognised. Once it shows there, make sure you change the Drive as your first boot device.
Thanks
Ranjit www.supportminds.com
Aug 14, 2009 | Dell Computers & Internet
PC will not read CD's on DVD drives
my acer 4520 cd rom is not working well when i press cd roms butten its not *** out & also in my computer its tht cd rom icon is not showing so plz give me the solution asap....
Jun 23, 2009 | Acer (91.AB264.001) CD-ROM Drive
CD DVD drives
try antoher cd-rom to see whether it's the optical drive or the pc>>>
May 25, 2009 | Tablets & eReaders
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Cannot find my CD-ROM on laptop
hi
check your cd rom case reattach it.
then if your problem remain go to your system properties .
remove your usb and your cd rom driver .then restart your system.
Mar 20, 2008 | Dell Latitude D600 Notebook
CD rom drive not working
sounds like it's gone home early. replacement will do the trick..
Mar 06, 2008 | Compaq Deskpro EP PIII-650MHz/ 128MB/...
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
