Question about Ovens
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Our microwave oven just stopped working, had put some instant cereal in
closed the door and it was just blank, no power or anything. It had power
before and had worked previously, flipped the breaker switch and that did
nothing. Its mounted in a wall cabinet above the regular oven, and the oven
works just fine. Any solutions?
  • rhooker1 Sep 24, 2008
    The problem was actualy the High Voltage Capacitor and the High Volatge Diode which also took the Fuse in the cabinet out when they failed.
    The problem as stated by MNtech was not the found poblem
  • lisapratte Mar 05, 2009
    My son put a quesadilla in the oven and hit the micro express button, closed the door and the whole thing went dead. I flipped the breaker switch but nothing changed. It is still completely dead.
I have a SCB2000BB o3 GE advantium oven that the bottom heating element does not light. The parts list shows a thermostat in line with the heating element. How do I replace the thermostat or lower heating element. Can those parts be checked to determine if they are defective?
Posted on Aug 05, 2014
It turned out to be the High Volateg Capacitor and the High Voltage Diode in the Micro wave section which also took out the Fuse in the cabinet
Posted on Sep 24, 2008
Turned out to be the High Volatge Capacitor and the high Voltage Diode in the Micro wave section which also took out the fuse
Turned out to be the High Voltage Diode and the High Voltage Capacitor for the Micro wave section, took out also the internal fuse
Posted on Sep 23, 2008
  • 1,543 Answers
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Posted on Sep 19, 2008
Replace outside glass
You have an expensive Monogram microwave so you can expect the parts to be expensive also. The outer glass assembly by itself ballpark cost is about $160 and requires a complete dis-assembly of the door to replace since the screws are all inside. Then if you go by the book--- the door should be checked for microwave leakage after the repair which requires a special test meter. They also sell a complete door assembly at around $300 that comes completely assembled. You need to compare that cost against the age of your microwave and possibly a new unit which I think is still available. Either way its not a cheap fix.
Apr 11, 2015 | GE ZSC2001FSS Advantium Electric Single...
Scb2000 GE Advantium 240 microwave not heating
It s the magnetron tube, thats what makes the microwaves. Not a hard fix, you can order one from sundberg.com or marcone .com with your model number
Jul 19, 2012 | GE Monogram 30" 240 Volt Black Built In...
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
I am getting arching in the oven when the only thing is themetal pan (rotating) the white dish and any food on the white dish What is happening?
Hello, thank you for posting your question on Fixya. I will be helping you with your Advantium oven. From your description it sounds like your having problem with the oven arcing. While you are using your microwave you can only have arcing occur while you are using the microwave or speedcook feature. While in either mode attention must be given to any mental in the oven. When microwaving place food and containers on the white ceramic tray only. The metal pan should be used during speedcook.
Happy Holidays!
Please rate "4 thumbs" if this was helpful.
Dec 23, 2010 | GE ZSC2001FSS Advantium Electric Single...
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
Microwave
Hi my GE Advantium oven is displaying an error message and beeping. The Error is F3. Could you please help me with this.
Nov 02, 2008 | GE ZSC2001FSS Advantium Electric Single...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Sparking when microwaving
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgh
Mar 08, 2008 | GE Profile Advantium SCB2001KSS Stainless...
Microwave
This would most likely caused by a door switch. It is either not being activated by the door not closing tight enough or the switch itself has failed
Jul 10, 2007 | GE Profile JTP95 Electric Single Oven
Ovens Logo
539 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
