Can not get channels - Televison & Video
    Sergeant:
  • 399 Answers
Try reset by removing all the wires and refitting all the wires in proper position again.
Posted on Sep 19, 2008
  • masterexpert Sep 19, 2008
    for the connections please check the instructions
    Here's How:
    1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
    2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
    3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
    4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
    5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
    6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
    7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
    8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
    9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
    10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
    11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
    Tips:
    1. If Cable TV is coming in directly from the wall with no Cable Box, the only option is to connect the Coaxial cable to the RF input on the DVD Recorder and then output to the TV using either RF, composite, S-Video or Component audio and video cables.
    2. Some DVD Recorders require you to make an RF connection as well as an A/V connection in order to use the Electronic Programming Guide (for example, Panasonic DVD Recorders that include the TV Guide On Screen EPG). Always check the owner's manual before making connections.
    3. Feel free to use connection combinations when hooking up your DVD Recorder. For example, you can connect from the TV source to the DVD Recorder using a coaxial (RF) connection and then output using S-Video and RCA Audio to the TV.
    4. Make sure if you are using A/V cables to connect the DVD Recorder to a TV, that you change to the appropriate input on the TV.
    5. Use the best cables you can for connections. Video cables from lowest to highest quality are, RF, composite, S-Video, Component. Which cables you use will be determined by the types of outputs and inputs on the DVD Recorder and the TV.
    What You Need:
    • DVD Recorder
    • Television
    • Television Source - either Cable, Satellite or Antenna
    • Audio and Video Cables
    feel free for further queries.
    thanks.
How do I add or remove channels on my Roku device?do i need to follow some activation process?
Tips and Trick to Add or Remove Roku Channels
Roku is a streaming device which offers you to choose from 1000's of channels. These channels are available on Roku Channel Store. The channels offer entertaining content for you all day long. Here are a few steps using which you could easily add or delete channels on your Roku. Channels are basically of two categories on Roku:
    ·Installed Channels
    ·Private Channels
    First let us see how we can add a channel in Roku device.
    Adding Roku channels is very easy in Roku all you need to do is to perform the Roku Account Setup for your device and then do the following
      ·Click the "add channel" option.
      ·Enter the credentials and log in to your Roku account.
      ·Activate your interest of channels.
      ·You could now exit the store.
      Removing an installed channel.
      To remove an installed channel the easiest way is to do it from the home screen by the following steps:
        ·Select the channels by pressing the Star (*) button of your remote.
        ·Then select the "Remove Channel" and press "OK" on your remote.
        ·Your unwanted channels are now deleted.
        The channels which are in the subscription can only be removed after the subscription is over.
        There is one more method of removing these channels i.e. through the Channel Store. For this you need to follow the following steps:
          ·Select "Streaming Channels" on the home screen menu.
          ·Select the channels to be uninstalled and press OK.
          ·Select installed channel option on the right side.
          ·Select Remove Channel.
          ·Your channels are now removed.
          Adding private channels with the help of Roku Account Setup.
          You could also add up some private channels to your Roku in the following way:
            ·Log in to your Roku online Account.
            ·Configure the Roku Account Setup.
            ·Select the "Add Channels" option.
            ·Enter the code within 24 hours and watch the channels.
            If you are still facing any technical issues regarding the setting up of your Roku account you could give a call @ 1-844-965-4357.
Sep 12, 2017 | Roku Televison & Video
Adult roku channels
    Adult Channels:
    Adult Channels additionally called private Channels are not showed in the Roku channel store for all average Roku users.
    Such channels are included physically.
    Adding the Adult Channels:
  1. Open the main screen by pressing the home button
  2. Select Streaming channels from channel store
  3. At top of the Channel Store is a list of new and well-known categories to explore.
  4. By using the search function, the user can easily browse their favorite channel.
  5. On the remote, Press Forward button to navigate to next page.
  6. If you want to know more details about the selected channel, Press ok on your remote
  7. If the channel is free, then you can install the channel directly on your Roku device.
  8. If the channel is paid, then you select to buy the option to purchase that channel and then install on your device.
  9. To include a channel by code you should login into your Roku client account.
  10. After that, within 24 hours the activated channel will appear on your Roku player's home screen and to "My Channels" in the Roku Channel Store.
Mar 28, 2017 | Roku Televison & Video
How can I access the channel store and add more channels ?
It's easy to add a channel or remove channels on Roku. After a while, the extra channels can make it hard to find the ones you want to use. That's when it's time to remove a channel from your Roku.
STEPS TO ADD NEW CHANNELS TO YOUR ROKU
1. Select a channel from the Channel Store to install.
2. Select the option "Add channel" and confirm the selection when prompted.
·If you have a PIN to setup, you will be prompted to enter the setup PIN number.
·Repeat this procedure for adding more channels to your Roku, or press the Home button.
STEPS TO REMOVE CHANNELS ON ROKU:
1.Go to home page, choose My Channels option.
2.Navigate to the channels you want to remove from your Roku.
3.Click the option (* symbol) on your Roku remote.
4.Select the option "Remove Channel" and then click OK. For the confirmation to remove the channel again you need to select the option "Remove Channel".
STEPS TO DELETE CHANNELS USING ANDROID MOBILE APP:
You can also delete channels from your Roku with the android mobile app or iOS.
1.In your mobile app, select the My Channels tab and click the arrow to the right of the screen.
2.Touch the Remove Button and confirm that you want to remove channels from your Roku.
If you are facing any issues while activating the Roku for adding or removing channels you can contact to their technical support team @ 1-844-965-4357
Jan 03, 2016 | Roku Streaming Stick
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
What is the frequency for UFR650?
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band. FRS Channel Frequency Assignments: Channel 1: 462.5625mhz Channel 2: 462.5875mhz Channel 3: 462.6125mhz Channel 4: 462.6375mhz Channel 5: 462.6625mhz Channel 6: 462.6875mhz Channel 7: 462.7125mhz Channel 8: 467.5625mhz Channel 9: 467.5875mhz Channel 10: 467.6125mhz Channel 11: 467.6375mhz Channel 12: 467.6625mhz Channel 13: 467.6875mhz Channel 14: 467.7125mhz
May 23, 2006 | Unwired UFR650 (14 Channels) 2-Way Radio
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
