Question about Lucent PARTNER18 Corded Phone
A beep/ sound when second line rings
When you are on the phone and another line rings it makes this really strange noise. I am guessing it does this to let you know that the other line is ringing.
Correct. When you are on a call, and another call comes in. You will get a "beep" and see the line flashing, after about the 3rd ring, you will hear another "beep"....etc...
Posted on Nov 20, 2008
Hi my laptop developed a strange problem. I formatted the system drive and installed a fresh copy of windows 7 ultimate sp1. now at the boot up the laptop makes loud annoying ringing bell sound for a few...
Is the "ringing bell" sound a series of beeps? A computer will have beep codes at start up for the user to identify system errors. Count the beeps, one long and 2 short or 3 short beeps or one continuous beep, etc. Then you can search to find what that specific beep code stands for. As for the the touchpad you may need to go into the system properties, right click on my computer, click properties and then click device manager on right. Click the "+" next to mice and other pointing devices. Double click on the touchpad device and then the driver tab. Click update driver and see if it finds a better driver. Or do a windows update. Sometimes the problem can be fixed there. Lastly, and oddly enough, try to take out your battery when the power cord is plugged in. I have seen cases where a bad battery can cause problems with the touchpad and keyboard. I hope one of these helps!
Sep 24, 2011 | Computers & Internet
Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
The phone doesn't like something it's sharing a line with.
First, check to see if the extension number on each phone is different. You may have two extension 11's.
Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
No dial tone, rings but cannot answer
Turn off the mains power at the base unit for a few seconds, then turn the power back on.
Feb 15, 2010 | Panasonic KX-TG1033S Cordless Phone
Beeping Sound
there is a possibilit that some components are disjointed now. try to get soemone take the parts apart and recouple it properly. my guess is that u could be having partial contact or a component is failing.
Aug 24, 2009 | Dual Electronics CECT P168 Cellular Phone
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Excessive vibration type noise on the line
Maybe your tugging on the wire to hard or there is a lose wire
Jun 27, 2009 | AT&T 1185 Phone
Toshiba laptop is slow and keeps making strange noises!
When any portion of the electronic package begins or is failing it can very well cause other problems. The different sections of your laptop all share power supply lines, cpu freq lines and memory lines. I agree that the hard drive could also be a culprit. Now you'll need to determine if this is an actual hard drive physical problem or is it virus' and spyware playing with the operating system. Is this what you paid that company to do? If so I'd be back there is a minute. What are the beep codes you're hearing?
Apr 15, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Intercom doesn't make beeping sound only flashes Merlin phone sy
Depending on the type of merlin system you have, you should be able to turn the ringers on by moving the switch on the left side of the phone marked T . P to the "p" position. All the lights should light and the set should ring every couple of seconds. Press the line you want to ring and enter *37, repeat for all lines you want to ring. If you want all lines to ring , press any line button and enter *347, slide the T . P switch back to the center "." position.
Hope that helps
Mar 27, 2009 | Inter-Tel Axxess Corded Phone
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Lucent PARTNER18 Corded Phone Logo
145 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
