Question about Brother Office Equipment & Supplies
Letters and numbers errors
When I push a key, the wrong letter or number is typed
  • Brother Master
  • 3,594 Answers
If this is a brother typewriter the the homing mechinism probably has a broken plastic spring finger.
Turn the T/W off let it restart then mark the the P/W with a touch of white out then restart it, if the P/W stops at a different place the above is the problem.
DickyO
Posted on Sep 19, 2008
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
Jul 12, 2011 | Computers & Internet
Letters on the keybords are all wrong
hi
i thing you software is not working you have to chack your manual
May 28, 2010 | Nakajima AE-830 Typewriter
Numbers take precedence over letters on shared keys
On my keybard I have a FN function key and F13 locks it. It lights an indicator.
Carl
Jan 11, 2010 | Acer NSK8458AN Keyboard
Hi, I've got 2 eeepcs, with identical problems,
When the RH side of the keboard types numbers instead of letters then the Num Lock (number lock) key has been pressed.
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Fn key plus and probably the Scroll keys, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Aug 13, 2009 | ASUS Laptop Keyboard for Asus Eee PC
When I try to type numbers...letters pop up.
press alt or arrow key and select the number key .........repeat the same when u want the number to get displayed in place of letters
Jun 28, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Hello, Kindly ineed your'Support ihave IBM Thinkpad Laptop keyboard function give output error i type u come output 4 wrong key fuction kindly ineed your;s help Thanks for your support with best regards,...
Press the Num Lock Key again to return to letters again, usually this is usually done by pressing the Shift key plus the ScrLk (Scroll lock) key, this key will be also marked NumLk, and there will be a LED light that will indicate when the number lock is on.
Jun 04, 2009 | IBM Thinkpad T43/p Notebook
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
