Question about Gateway Computers & Internet
Address bar missing,gateway advertisment displayed
  • 177 Answers
Under Tools in IE choose Toolbars and choose the necessary Toolbar you want displayed.
Posted on Sep 19, 2008
Is uPNP disabled/enabled by default
Universal Plug n Play is generally disable by default and will need to be enabled by typing your Router's Gateway into your browser.
Every router has different methods of logging in so you'll need to refer to your documentation and find out what your Username/Pass is by default.
To get your Default Gateway:
1)Start -> Run -> Type cmd ->
A box will pop up, type ipconfig
2) Look for Default Gateway. This is the address you type into your web address bar just like you would type in a regular website.
3) Navigate to your System Settings. Look for the following key words: Advanced, Network, UPnP settings, etc.
4) Check the box to enable. You can leave the default settings regarding the advertising period if you're not familiar with it.
5) Hit Save Settings/Apply. Your router may need to reboot.
6) Reboot all systems connected to your router to make sure they all have the fresh settings.
If you need more help please respond with the router's full model number and I'll happily give you step by step instructions on how to configure UPnP.
Mar 07, 2016 | Konica Minolta Office Equipment & Supplies
I can't open my thomson gateway
What's the error message?Have you tried to go to the exact modem page?
1. open internet explorer2. type the numbers 192.168.1.254 on the address bar then press enter3. you will be routed to thomson page settings if you received any message stating error like can not display page then you need to check if the cables are properly connected.4. if still can not connect, go to the start menu icon5. select the run icon or search bar6. type cmd then press enter7. you should received a black screen8. from the black screen type ipconfig then press enter9. you should received the info like IP ADDRESS, SUBNET MASK and DEFAULT GATEWAY.10. copy the default gateway and type it in the address bar of your internet explorer then press enter11. if you have not received these information (ip address, subnet mask and default gateway) on the black screen after typing the ipconfig then check the error "media state disconnected" which means that your pc and your thompson is not communicating, here you need to try different network cable to isolate issues for the problem might be the cable, network cable port at the back of your pc or the network cable port at the back of the thomson.
kindly rate rate this post, thanks
Dec 31, 2011 | Computers & Internet
I have a belkin g router. I am able to connect hard wire but not wirelessly. Not sure if i am missing a step. I tried rebooting the router and reinstalling it......no luck.
were you able to connect to that router before? If not then do the manual checking of wireless settings, get you default gateway ..how? http://www.ehow.com/how_2091470_computer-ip-address-windows.html instead of looking for Ip address .. look for default gateway it should be after subnetmask or if you havent change any settings on your router if the default gateway should be :192.168.2.1 -then open any of your browser like internet explorer or Firefox and type in the default gateway in the address bar (make sure during these steps your computer is currently connected to the router hardwired) -Do the wireless settings, here's how: http://en-us-support.belkin.com/app/answers/detail/a_id/3774/related/1/session/L2F2LzEvdGltZS8xMzA5ODU1NTc5L3NpZC84a1NuZ2N5aw%3D%3Da also what is your OS is it XP or windows 7, as well as check you wireless capability on your computer if it is ready for wireless connection...
Jul 04, 2011 | Belkin (F5D7633UK4A) Wireless Router
Wii will not connect to internet
Try to change the router channel number. Nintendo suggests to put it on ch 7 or 11. You can do this from a computer that is connected to the internet through the same router. Open up a browser an in the address bar type in your default gateway to login into your router and change the options. Each router is different and might have different default gateways. For example Netgear routers usually have the default gateway 198.168.1.1 but others will be different. You can find your default gateway by:
WinXp
1.Click start
2.Click run
3.type cmd - enter
4.type ipconfig - and it will display your info.
Win7
1.Click start
2. type cmd in the search bar and when you see cmd.exe click it once (usually the top find)
3.then type ipconfig - and it will display you info
After you find your default gateway number type it into your browsers address bar, no www or http needed. Just type it as it is.
Each router's configuration page is different so I would suggest that you consult your manual on how to change the wifi channel, or broadcast channel, or even radio channel. All of those sould be terms that are used. Hope this helped.
Feb 04, 2011 | Nintendo Wii Console
My wii sucks and wont connect to our internet
WinXp
1.Click start
2.Click run
3.type cmd - enter
Win7
1.Click start
Hp leserjet 4250n network ip change solushion
Print out the current configuration of the printer, Press the Tick button, navigate to Information, press the tick button, navigate to Print Configuration, press tick button.
On the printout find the current IP address. Open a web browser and type the IP address into the address bar, press enter.
The printer setup will be loaded into the web brower. Navigate to the network configuration so you can see the IP, gateway and subnet IP addresses.
You can now change these but once you have your browser dispay of the printer will disappear.
Type the new IP address into the web browsers address bar and you should get the new configuration displayed.
Sep 03, 2010 | HP LaserJet 4250n Printer
May address bar was missing
Check Menu bar->View and select the missing bar.
May 20, 2010 | Computers & Internet
How to open NAT on router
To open NAT
On the Windows Desktop, click Start.
2 Select Run. The Run window is displayed.
3 Type cmd /or/ command and click OK.
4 On Command prompt window (black screen) type ipconfig
5 Check the Default Gateway (192.168.?.?)
6 Open IE - on the address bar type http://192.168.?.? enter
It will open the router page
Gateway > LAN — nat config Page
Check Page No 47 on the Manual
Check the Manual
SBG1000 Wireless Cable Modem Gateway User Guide
Enable NAT If enabled, the single HFC IP Address (public IP address) assigned by the cable service
provider is mapped to many private IP addresses on the SBG LAN.
Jan 04, 2010 | Arris SBG1000 Wireless Cable Modem Gateway...
Missing video diver for gateway labtop MA1 is all i know about the model
http://support.gateway.com/support/drivers/search.asp?ref=nofind&ct=fn&param=gtwupd.exe
Gateway has a Scanning program that automatically updates current and missing drivers
Click on the link a few times until its all highlighted
Open a new internet window
Paste it in the address bar
Hit Enter
Download the Program
Install
Run
Good Luck!
Blazamane
Jan 07, 2009 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
