Question about Microsoft HannsG HU171D 17" LCD Monitor
Have black vertical bar on right hand side of screen of hg221a monitor. have tried all the resolution setting but no difference.
Black border on all sides of screen, reduced desk top all on windows Vista
Right click on your desktop screen and click screen resolution,click on resolution and try a different setting.Keep changes and click apply.If that helps,keep trying different resolutions until your desktop is right for you :)
Sep 05, 2014 | Acer Computers & Internet
Tip
How to set your Desktop Screen Resolution?
Greetings, Welcome to Fixya!
So you need to adjust your Desktop Screen Resolution ey!!! It's a good thing you visited as today we are going to discuss just that.
We will be using our monitor to it's full potential, which will ensure we see the best picture our monitor can provide.
Follow the steps below:
1.)Right click on your desktop screen.
2.)A rectangular menu box appears.
3.)Select Properties, found right at the bottom of the menu box.
4.)Select the Settings Tab, found on the top right hand side of the window.
5.)On the bottom left hand side you will notice a slider bar under the heading Screen Resolution.
6.)Move this slider to the left to decrease the Screen resolution, less detailed, move the slider to the right to increase the Screen Resolution, more detailed.
7.)Ensure that the colour quality is set to highest, to give a more detailed and clearer picture!
Below: The window, see the slider bar on the bottom left and the colour quality on the right!
That should do the trick!
Now you will enjoy all the detailed, crisp, goodness that your monitor has to offer.
Thanking you
Till next time!
damnor01
on Dec 14, 2010 | Computers & Internet
Acer V223W off center
it happened to me. I changed computers but that did not solve the problem so it's not the video card. what did help was I turned off the monitor to reboot it then, using a different computer I reset the resolution to the lowest possible setting. when the monitor adjusted to the new resolution it reset itself. I then set it back to the higher resolution and everything was centered again.
Mar 12, 2013 | Acer V223W 22 inch Monitor
How do I change my computer monitor to 1680 x 1050?
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig. below, click on the settings tab at the top right of the box.
The areas worth noting are: google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
Color Quality
This pull down box will contain the current colour options available, again this will depend on your grahics card and monitor, for best results select the highest option available.
Changing the ResolutionTo change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
When you have finished simply close the Display properties box.
Jan 13, 2011 | Computers & Internet
Black strip left hand side of moniter screen not being filled
The monitor should have some kind of menu, accessible through the buttons on the side or bottom. In there you can move te display area to the left. If you then get a bar to the right, you should change the monitor resolution to the highest it can display.
If the bar on the left persists, you should check wether the PC-monitor cable is properly insterted. If so, try another cable. If that doesn't help either, try another monitor.
I hope this helps,
Yannick.
Oct 05, 2009 | LG L192WS LCD Monitor
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Windows XP not fitting full on 22 inch computer screen
Your new monitor will show a "native resolution". In the instructions below, try that setting first. If that fails try other settings.
- Right-click on an empty spot on your desktop
- Chose "Properties" on the menu that appears
- Click the "Settings" tab (at the top right)
- Move the "screen resolution" slider to a different number
- Click "apply"
- See how you like it
- Repeat until you get a setting you like.
Dec 27, 2008 | Computers & Internet
I have a u220w monitor which has a rectangular screen but the picture is square leaving both sides black for about 3 inches on each side. I want to fill the entire screen. I just had the windows vista...
Dear You need to adjust the computer resoultion to one of the following..
1088 x 612
1280 x 720
1360 x 768
you can increase it more; depends on your graphic card installed in system..
HOw to change the resoultion??
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box (see left), if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
Let me know if it helps...
rate me..
regards,
Dec 04, 2008 | Computers & Internet
Black vertical belt in both side
This sounds as if you havent got the correct resolution of your desktop. Either there will be an auto adjust button to press on your monitor menu or you will need to Right click on your desktop>properties>settings Tab and change resolution to 1024 x 768 or similair to change the desktop size, or maybe reduce to 800 x 600 then click apply.
Dec 08, 2006 | Hansol 730E 17" CRT Monitor
Microsoft HannsG HU171D 17" LCD Monitor Logo
129 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
