Question about Vivitar 285HV Flash
Sevice manual for 285HV?
Hi rkrenn,
I was reading some posts where the service manual of the Vivitar 285HV was requested. If I understood well, you are the happy owner of it. As I need to modify the flash, would it please be possible to email it to me? I would be forever thankful!!
greetings and 1000 thanks in advance!
Hans
(hansgonidis@gmail.com)
    President:
  • Vivitar Master
  • 1,734 Answers
Most probably find a Vivitar service manual here. Just send them a search request.
Posted on May 29, 2009
How many kind of manual flash making vivitar company slr camera
As far as I know, every Vivitar flash can be made to fire in manual full power mode. No exceptions. Even the modern full dedicated E-TTL units can fire manual full and fractional power levels.
Sep 10, 2014 | Vivitar 285HV Flash
How to remove sensor from Vivitar 285HV Flash
Pull it straight out from the body. See the instructions on page 9 of the manual.
Oct 22, 2012 | Vivitar Used Replacement Vari Sensor...
Bought the 285hv over 10 years ago. has never been used. tried to use it recently and absolutely nothing happens? any suggestions? thanks!
Capacitor might got dried up.
Try using fresh Duracell Alkaline and wait for 15 minutes.mostly light will come up.if not replace capacitor by professional service.
Sep 28, 2009 | Vivitar 285HV Flash
Vivitar 285 not working
You don't need a Manual.
In 285 HV there is only one Power on/off switch.
If that switch is on and batteries are new Alkaline (like duracell-no chepo )or fully charged and working rechargebles,and yet the ready light do not come the flash has defect inside.For sure.
Jul 27, 2009 | Vivitar 285HV Flash
285hv bulb blew out
The flash tube for these kinds of units are not user changeable- high voltages and electronics technical expertise are required for safe and successful replacement. Find a qualfied service facility through your dealer.
Nov 22, 2008 | Vivitar 285HV Flash
Can I use my Vivitar 385 with my Pentax K200?
Yes, you can use the flash if your camera has a PC connector.
Or, check the trigger voltage: under 7VDC = OK on hotshoe.
atlee@netzero.com
Oct 31, 2008 | Vivitar 285HV Flash
285 FLASH
Yes, no problem.
In Auto and Manual Modes, not TTL.
atdlee@netzero.com
Apr 07, 2008 | Vivitar 285HV Flash
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage...
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Jan 08, 2008 | Vivitar 285HV Flash
Need diagrams for a Vivitar 285HV Flash
I had the same problem on a new 285HV flash. I pulled it apart and found a blown resistor and track in the head of the flash.
The flash was fairly easy to pull apart, there is a clip hiding behind the blue disk, the rest is just screws.
There are 3 circuit boards, two in the base and one in the head.
The blown resister is in the head and is the large resister next to the violet wire. From the edge of the board there is R22 brown-black-brown, two diodes, another resistor yellow-violet-brown and then the one that died.
I have the service manual for the flash and it is titled 285/285HV but the circuit board in the service manual and in the flash are different.
After much studying of the circuit diagram I believe the value of the resister is 12K 2watt (90% sure, if not it is 10K 2watt).
I replaced the resistor with the 12K and was able to use the extra length of the leg of the resistor to bypass the blown track, used some heat shrink to insulate the leg from shorting out with the board.
I have tested the flash and it is working but I have not used it extensively.
Disclaimer: this board is right next to the capacitor, you don't want to touch it if it has a charge. Use a multimeter to check.
I bought the resistor from here: www.digikey.com Part No. P12KW-2BK-ND $0.206 (min order 5 still only a $1.03)
Good luck and remember I am not an electronics tech and your problem may be different to mine.
Richard
Jan 07, 2008 | Vivitar 285HV Flash
Vivitar 285HV Flash Logo
167 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
