Question about Denon DVD-2910 DVD Player
Denon dvd 2910 locked up
My player has worked fine for 2 years. I went to play a dvd and it's locked up. Display shows '2910', and no buttons work including drawer open or standby.
Remote doesn't work either. Tried factory reset in tech manual. Power was plugged into Denon receiver and receiver was plugged into excellent surge protector...so almost positive no electrical surge went to player. Is there another master reset for unit. Thanks.
  • thehwguy Dec 01, 2008
    I have exactly the same problem. My player is coming up to 3 yrs old now and regularly locks up on certain DVDs. I'm quite certain it's not a disk problem - it's a hardware/processor lock-up after a second or so of total image break-up. Only fix so far has been to power-cycle the player. Not good. I will be contacting Denon soon.
    Top Expert:
  • Denon Master
  • 78,267 Answers
You will have 2 choices here, replace it or have it repaied
Posted on Jul 06, 2017
3 Suggested Answers
SOURCE: Denon 2910 CD player malfunctions
By this time I figure most peoples warranties are expired. So give this a try:
1 Open the case.
2 Turn the unit on and load a disk.
3 On top of the disk transport, you will see a black disk trying to spin as it reads the disk. You might notice that it is a bit quite as the display goes to 00H00M00S. It should be fast and a bit noisy.
4 Try loading a disk again, except this time, try to help that little black disk spin. It might take a couple of attempts, but I was able to get my 2910 working again.
The last year I've had to do this 2-3 times. But it works. From what little I have read, it may just be an issue with lubricating the right part with the right oil. I've narrowed my choices to PTFE 3n1 oil, Lithium oil, or silicone oil.
now I just need to find the right places to oil.
There should be quite a bit of noise and speed
Posted on Sep 11, 2008
  • 4 Answers
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Posted on Jun 14, 2009
My Denon dvd-2910 does not play 5.1. It is connected to Denon AVR-3805. It plays just stereo. The center, back channels and subwoofer don't give any sound
Your Denon DVD-2910 produces left and right audio output. Your Denon AVR-3805 generates 5.1 channel output; therefore, 5.1 channel output may not have been selected or the AVR-3805 may be defective.
Jan 29, 2017 | Denon DVD-2910 DVD Player
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
Progressive scan problem
You need to clean your laser lens my friend. If that does not help, I'm afraid then that your laser assembly is going bad and on its last leg. The first clue to this is that you stated that the Cd's work and the DVDs do not work properly. The laser, when it gets weak, starts to mess up on the Dvds first but the Cd's will soon follow. Good Luck
Sep 05, 2007 | Denon DVD-2910 DVD Player
Denon Dvd-2910 only displays black and white on the tv screen
this is not a serious problem. It just has to do with visual compatibility.
Change the DVD display to Pal or NTSC and set that of the TV to Auto or pal.
You might find the PAL/NTSC on the DVD remote, or on the button of the DVD. If it is not there, then Check display settings of the DVD.
As for the TV, Change to Auto or Pal from display settings.
Take care.
Jan 01, 2010 | Denon DVD-2910 DVD Player
Unlock Deno 2910
Initially, pls try:
  • Verify that the tray is empty/no disc in the player;
  • Shut down/off with the front panel On/Off button and not the standby;
  • Press and hold the Open/Close, Play and Skip Reverse (I<<) buttons;
  • Maintain pressing on the above buttons and Power-ON the player with the On/Off button, (again while still holding the above buttons till the "Denon 2910" disappears from the display);
  • pls wait till LOADING completes and the front panel would display 0:00:00;
  • Using the remote control, enter 7, 3, 1, 9, 4, 6, 2, & 8;
  • The Denon 2910 will go into standby mode. Soon as it is on standby, pls press the Standby button on the front panel;
  • Pls verify region free update by pressing the Stop and Skip Forward (>>I) buttons on the front panel. The display would show “Region_Ax” The x would be the former region number that the Denon 2910 is locked into;
  • Should it not work ouot as expected, pls redo all the above steps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Denon DVD-2910 DVD Player
Denon DVD 2200 front control buttons don't work
I have had the same problem. After disassembling and refitting the buttonpanels and it's connectors the problem was solved. Does not seem like a repair but in my case it still works for about two years now
Jul 19, 2008 | Denon DVD-2200 DVD Player
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
Stuck on DEMO Mode
Just try to initialize THE plager again. Without cd in the player switch on the power while pressing the Play, Open and Next Track button. On the display it says " initialized" Ready. Frits van Heekesen Nijmegen The Netherlands
Dec 27, 2007 | Denon DVD-2200 DVD Player
Nov 06, 2007 | Denon DVD-2900 DVD Player
1 Open the case.
Nov 04, 2007 | Denon DVD-2910 DVD Player
Denon DVD-2910 DVD Player Logo
102 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
