I've been using winfax for 8yrs, im on xp pro, ser pak 3 and now unable to send a fax. i can use the macros to print to fax info, but when i hit the send button, it does nothing. the fax doesnt show up in the outbox at all and the program i still running. no other issues but this.
same problem, XP s/w, cannot send new documents to fax, send window appears blank, can resend faxes already in winfax folders, just cannot send
new ones. was sending ok earlier in day using word, when i tried to send an excel file, system froze and have not been able to send since. have removed winfax 10.03 sw and reloaded and same problem appears. this is probably not a winfax problem, maybe another s/w upgrade impacted this, i havent loaded any new XP fixes, but mcafee updates have occured on regular basis.same problem, XP s/w, cannot send new documents to fax, send window appears blank, can resend faxes already in winfax folders, just cannot send
You can't post conmments that contain an email address.
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
click on Start > all programs >accessories> System tools> System restore.
When restore window comes up select "restore my system to previos state" after thet select 3 day before date it's looking "dark" select and click restore.
This is a solution that was suggested for an earlier edition of the Winfax Pro, but there is no reason why it shouldn?t work on this one as well:
1. Close Winfax and any other program that has anything to do with it, delete all the temp files that yo don?t need.
2. Run Scandisk and fix any problems that may come up.
3. Run delfix.exe which is located in the winfax folder in the status files.
4. Run delfix-rebuild and delfix-optimize and check if the problem is solved.
If the problem reoccurs there is another possibility- to change the name of the WinFax\data folder and create a new one which you will transfer the address book file, status files etc. from the old folder. Note that there might be some information that wouldn?t go through.
