Hi I've got a 24i Worcester boiler which has stopped working for some reason. It was fine last night but this morning the red flashing warning light is on (flashes once per second) & it's not igniting. The gas supply is fine. I've let in water so that pressure guage now reads 2 but this doesn't seem to do the trick. I've also pressed the warning light in for 5 secs to see if it rights itself but no joy. Any ideas? Thank you
  • Anonymous Oct 31, 2008
    warning
4 Suggested Answers
  • 15 Answers
SOURCE: I would like to know
Most user manuals are online at Manufacture webe sites. That would be the most reliable place. Sometimes the manufacture to appliances will be more top level for example GE is the manufacture of Hotpoint ect.
Posted on Nov 28, 2010
  • 3074 Answers
SOURCE: Worcester 24i boiler..how do i
Overheat thermostat has tripped. If a modern Worcester need to press reset on control panel.
If older style Worcester - Pull front cover off the boiler (just above control panel flap pull the cover from both sides forward to unclip and then lift upwards to remove cover) and you will see a little brown reset button - press this back down.
However the over heat thermostat trips for a reason - was the system running on low pressure? It could be the pump is sticking a bit (dirt in the system) which can be sorted easily by adding an additive (DIY packs available at Home-base) . Or it could be the pump has completely gone. If this is the case it will trip again as soon as the boiler clicks back on.
Posted on Apr 27, 2011
SOURCE: MY WORCESTER COMBI BOILER 24i
when i open the tap for hotwater i can see only the flashing light on and not hotwater at all the guy changed the fan but after changing its no use waste of money i still have this problem i dont want to spend more on it can some one let me knolw the problem so that i can fix ir my self .
Posted on Jun 23, 2011
Worcester 24i instructions
I'm assuming your talking about the water pressure in the system?
Aug 27, 2014 | Heating & Cooling
Is there an exploded view diagram of worcester 24i boiler
Try www.heatingspareparts.com - they've got thousands, and the registration for viewing's free as well.
Feb 22, 2012 | Water Heaters
MY WORCESTER COMBI BOILER 24i JUNIOR SUDDENLY STOP WORKING. THE WARNING LIGHT IS FLASHING. THE BOILER IS ABOUT 5 YEARS OLD.
Jan 18, 2011 | Heating & Cooling
My Worcester 24I combi boiler not working - I have no heating or hot water. I've adjusted the pressure guage to 2 but nothing is happening.
look on the worcester wed site you can down load amanual for this with a fault chart in it , look for a button red?? could be the res et poped out 2bar is too high should be 1.5bar hope this helps
Sep 25, 2010 | Desa International SPC-24IR Utility Heater
Flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Nov 08, 2009 | Water Heaters
Flashing red light under ! on my worcester 24i junior combi boiler and pressure under 1
you don't have enough pressure in the tank you are using, needs to be a 2lb system to work properly it is starving the gas valve for gas
Apr 19, 2009 | Water Heaters
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
