Question about Bionaire Air Purifiers
Bionaire BAP825RC red led light
I have a bionaire BAP825RC Purifier, which i bought 2 months ago, it stayed off for 1 month, and when i turned it on again the filter light (red led) blinks twice and the unit doesn't do a thing.
I tried reseting it holdin the power button for 2, 10, 30 and 60 seconds, and nothing.
There is no little black dot or hole next to the green led leight as far i can tell.
Can someone help me out eith this?
Thank you
4 Suggested Answers
SOURCE: Bionaire filter replacement- reset indicator
I think that this method for resetting the filter does not work UNLESS you first unplug the unit. (Note: I have tried this only on model BAP1175/1300. I recommend unplugging it for an hour, but I really have no specific minimum time for this; in the past I unplugged it for five minutes as recommended by Bionaire phone tech personnel, but the reset did not happen.) Then, after an hour, plug in the unit, and press the On/Off button (on my unit, this button reads, "Off") and Sleep button (on my unit, this button has a "crescent moon" icon) simultaneously. (Again, not sure how long, but I recommend that you hold these down for at least 20 seconds.) Then, you can turn the device on, and it should reset to 99%. Good luck!
Posted on Mar 09, 2008
  • 114 Answers
SOURCE: Black Filters for Bionaire BAP1500
the only other places that you could check would be like a hardware store. kmart, wal-mart. if you have those in your area. ace hardware. places that would normally carry that unit. the big ones mainly are lowes and menards.
Posted on Aug 20, 2009
  • 114 Answers
SOURCE: I have recently purchased a bionaire bap 1550 air
no that isn't normal. it should be coming out of both sides cause the air intake is in the back of the unit where the filters are. try to reset the unit but the pin hole at the top or unplugging the unit for about 10 seconds.... if that doesn't work i would call the manufacturer and to see what other ways or if the unit can be replaced.
Posted on Mar 18, 2010
Are Bionaire F150/150S/150W available?
Refer your inquiry directly to Bionaire.
Jul 21, 2014 | Bionaire Air Purifiers
Bionaire BAP1300 -- Working fine for 2 Days then, Red Light
Try to do a hard reset by unplugging the device from the power outlet and wait for sometime to reconnect.
Jun 09, 2008 | Bionaire BAP1300 Air Purifier
Tip
BAP1500 FILTERS GOOD TIP FOR RECYCLING!
I had a Bionaire BAP1500 which was broken, light up but nothing happens.
i also have a BAP412 and BAP242 which need to have their filters replaced every 3 months - which is very expensive.
I thought i would try the permatech filters from my 1500 in the other 2 purifiers to see if they would fit - they do! and they both work perfectly with the filters installed..no more buying filters for me
So just a tip to say if you have a BAP1500 and its broken, keep the filters because you can use them in a much cheaper model!
on May 09, 2008 | Bionaire BAP1500-U Air Purifier
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
Mar 29, 2009 | Bionaire BAP1500-U Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Replacement Filter
i do apologize for the inconvenience that your having with the product. The only other thing that i can suggest cause you already did the majority of the troubleshooting, is that there should be a small pin hole on the top of the unit. that's the reset. stick a small pin in there and hold for about 3 seconds and then the unit should be reset. if that doesn't work there is something internal that is going on. recheck the manual for the trouble shooting options as well.
Oct 14, 2007 | Bionaire BAP815B-U Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Air Purifiers Logo
99 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
