Question about Dell Inspiron 5100 Notebook
Help with Dell 5100
I have a dell 5100 that turns on when it want to. Most of the time it does not turn on. When your try to power it on you can hear the fan turn on for about 2-3 seconds and then it stops and don't power on. Any suggestions?? Please help!!!
  • StormRover Jan 23, 2009
    A friend of mine gave me a laptop... he said if I could fix it I could have it. The only thing I can get it to do is flash the battery light when it's plugged into the charger, and it will power on for about 3 seconds, then shut back off... nothing comes on the screen, and only the fan and drives can be heard. Can somebody give me a starting point?
Can you upgrade cpu in dell 15 i5559-4682slv to i7 ?
It is almost impossible to upgrade proprietary makes like Dell and HP. The are big enough to have motherboards made for them manufactured on price point. This means that they are not built with upgrade in mind. Also the cases are made to fit their motherboard and theirs only.
Go to a computer builder and get a good case, buy a good quality motherboard and equip it with what you can afford. In two years you can upgrade as processors have moved on. Two years after that, you can swap out the motherboard, processor and memory.
Jan 12, 2017 | Dell Computers & Internet
How do i turn off the HDD
What happens when entering the sleep mode is the drives will be turned off and the present state will be kept in memory until awakened. While the system is active the power scheme will prevent the drives from idling down after so many minutes with the never turn off setting applied.
With the turn off drives after the default 20minutes of inactivity that doesn't mean all drives turn off at the exact same time. I've never come across any reference for changing the power plan option for individual drives. But I can point you at the guide for the power plan settings with one instruction on drive settings to apply prior to entering the sleep mode.
hope that helps if not let someone here know.
Oct 03, 2014 | Computers & Internet
How to enable bluetooth
Your computer has to have a bluetooth radio. You can check
Control Panel > System and Security > Device Manager
Do you see a Bluetooth Radio listed?
If not, you don't have BlueTooth on your computer so you will have to add a BlueTooth device by plugging one into a USB port.
If you have a BlueTooth radio, go to Control Panel > Hardware and Sound > Device and Printers > Add a Bluetooth Device
This option is used to connect a blue tooth device (e.g. bluetooth headphons) to your laptop through your bluetooth radio.
See this Windows web page for more information.
Set up Bluetooth enabled device
I will respond to any additional questions you have.
Aug 05, 2014 | Dell Inspiron Computers & Internet
Error code 0151
hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
Apr 12, 2014 | Dell Vostro 1015 Laptop Computer (Intel...
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Jan 28, 2014 | Dell Vostro Computers & Internet
I can receive email on yahoo, but can not forward anything from my email account with yahoo
hey roger,
You will need to check your outgoing smtp settings in yahoo. Below is the information to set this up.
1) Yahoo! Mail Settings (if allowed)
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)
Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
2) Yahoo! Mail Plus email server settings
Yahoo Plus Incoming Mail Server (POP3) - plus.pop.mail.yahoo.com (SSL enabled, port 995)
Yahoo Plus Outgoing Mail Server (SMTP) - plus.smtp.mail.yahoo.com (SSL enabled, port 465, use authentication)
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Follow Dell on Twitter @dellcares
Mar 28, 2013 | Dell Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Dell Inspiron 5100 Notebook Logo
148 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
