Question about Lexmark Z615 InkJet Printer
Lexmark z515 printer, green light flashing once, then twice, repeatedly.
Printer won't print. it is actually a z515 model. I have a Lexmark Z615 doing the same - green light flashing once then twice repeatedly. Did you find a solution?
Thanks.
  • starleatamax Sep 27, 2008
    Im having the same problem with my Lexmark Z615. I put paper in and it starts to feed but it goes to the side and then jams. Then i get a message to load paper in the feeder and it has plenty of paper. I would really like to know how to fix this problem.
  • tomlinks Oct 13, 2008
    It starts to print the first page of my document but at some point on that page it stops printing, a message flashes up on my laptop to say the print has been cancelled and on the printer the green light flashes once, and then twice repeatedly. Ive printed the document 6 times now and never made it to the end of the first page
  • 83 Answers
SOURCE: millennium driver for Lexmark z515 printer
TRY THE CD IF YOU HAVE IT IF NOT TRY THIS LINK
http://rapidshare.com/files/93555208/CJA510EN.exe.html
IF THIS DOES NOT WORK, YOU MIGHT NEED TO UPGRADE TO WINDOWS 2000 OR XP OR GET A COMPATIBLE PRINTER
Posted on Feb 21, 2008
IB4G2008
  • 3587 Answers
SOURCE: Lexmark z615
you can find those drivers here
Posted on Mar 11, 2008
SOURCE: Lexmark Z615 Color Jet Printer softwere
help me please a lost my cd .
Posted on Oct 23, 2008
ginko
  • 19396 Answers
SOURCE: lexmark z615 printer drivers
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,find the file,double click on the file , then if you get introubles,follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:someprinter doesnot work on Vista, if you do not find any driver downloadfor Vista onyour model page, that means your model is not Vistacompatible.
Posted on Oct 25, 2008
Techvisitor
  • 63 Answers
SOURCE: Lexmark Z515
You downloaded from the correct site. It is compatible with Vista. Sounds like a download that got corrupt along the way while downloading.
Did you download the file:
cjrZ500-Z600EN.exe ?
Delete the file you downloaded and try again. Except this time, SAVE the file to your desktop perhaps.. (doesn't matter where.. just don't select RUN when you click to download the file)
If you cannot run any other programs.. and get Invalid Win32 application for other items.. then you may have a problem with file association. Can you run any other exe programs?
Posted on Nov 03, 2008
How do i print a test page on a lexmark z515 after i install the cartridges
Please follow the steps below on how to print a test page on the Lexmark Z515 printer:
  1. Go to Start, Programs (Windows XP: All Programs), Lexmark Z510 Series.
  2. Click on Lexmark Solution Center.
  3. Click on the Maintenance button on the left of the screen.
  4. Click on Print Test Page.
I hope this helps. Thanks.
Nov 15, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have a Z615 lexmark printer. when I try to print , it clunks and the green light starts to flash twice repeatedly. the message then comes up saying check connections, paper etc and try again. I do this...
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check the light status.
8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print a document again to verify that the problem is fixed.
Nov 08, 2011 | Lexmark Z615 InkJet Printer
Sir, my lexmark z615 printer suddently printing blank papers and it shows the ink level low even though it is fully refilled. still the problem persists.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 01, 2011 | Lexmark Z615 InkJet Printer
Just installed new printer Lexmark E260dn all lights flashing- printer does not print
This light sequence means that the printer has a service error, and printing has stopped.
Please Press Continue button (green button) twice to see the secondary code. The secondary error code will help locate the problem. Please take note which light will be flashing for this will reveal what problems you have on the printer.
For further assistance, please contact Lexmark Technical Support.
Feb 20, 2011 | Lexmark E260dn Laser Printer
My black cartridge is good but i cannot print in black
Try to clean the nozzles on the black cartridge using a damp paper towel. How to Clean the Print Cartridge Nozzles and Contacts Manually. Then try to print to see if problem is resolved. You can also refer to these articles:
- How to Clean the Cartridges of the Lexmark Z615 Color Jetprinter in Windows - How to Clean the Cartridges of the Lexmark Z515/Z615 Color Jetprinter in Mac
I hope this information has been helpful. Thanks.
Feb 17, 2011 | Lexmark Z615 InkJet Printer
Lexmark printer lost cd how do I install
Go to the Lexmark site, once you've chosen North America, United States and English, choose your Printer by Model, enter Z515, then choose operating system and download software...
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 11, 2009 | Computers & Internet
Lexmark z615
yes there is a solution.nothing to worry just click the link directly ,then select your operating system and download the driver http://www.siliconguide.com/drivers/device/216/
this will help thanks.
Jul 12, 2009 | Lexmark Z615 InkJet Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Printer Problems
MY LEXMARK Z615 DOES NOT WORK WITH BLACK CARDIAGE
Oct 13, 2007 | Lexmark Z615 InkJet Printer
Lexmark Z615 InkJet Printer Logo
298 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
