Question about Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC- 8M
I am wanting to buy a cuisinart food processor. I am thinking of buying the DLC-8M, is this a good one and is it an 11 cup? I am wanting an 11 cup,. I have also seen a DLC-8E, and 8F out there. Does anyone know when each of these were made. Do they last or should I get a newer version? Any thoughts would be helpful!
Thanks,
Melodie
  • 8,596 Answers
Those older Cuisinart food processors have motors that generally last forever. But a replacement bowl can cost $118.00 or more. The newer processors like the DLC-8S do have a 3-year general warranty and a 5-year motor warranty. The new DLC-2011, 2007, 2014 series etc. have 10-year motor warranties. I like the collect the oldies, but the new ones have few problems even though they are made in China. If an old processor's plastic breaks, you have to buy a completely new bowl set - if a new processor's plastic breaks, then you can buy a single component piece to solve the problem. Hope this helps.
-Tha Mp3 Doctor
Posted on Dec 09, 2008
How do you replace the power cord on a Cuisinart DLC-8M.
put the screws back and leave the cord alone it still works
Jul 13, 2016 | Cuisinart Food Processors
Is the Cuisinart DLC 7 Super Pro Manual available to download?
Manuals can be found here:
Food Processors Product Manuals Cuisinart com
You'll have to look around at the options and pick one that looks like the one you have.
If you have an older one, the handle for the bowl generally goes in front, and check the base to see if the button that gets pushed down when the top is in locked position is in the front or the back... and try to match that. The DLC-10s has it in the front (7 cup machine), but many of the larger machines have it in the back. The feed tube matches up with the button when you put the lid on. If you put the lid on with the feed tube 180 degrees off, you can break the lid/bowl getting them apart again.
Getting this right is the most important thing... otherwise they just kind of work. The link for the 7-cup Pro Classic Food Processor (DLC-10s) has really good technique information with color photos. It's worth grabbing regardless of the machine you have.
http://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Other manuals have other recipes... so you might want to download more than one manual.
Jul 03, 2014 | Cuisinart DLC-5 Food Processor
Need instruction manual Cuisinart DLC2011NC
Hi Theresa: Your Instruction and Recipe Booklet for the Cuisinart DLC-2011N Premier Series 11-Cup Food Processor may be downloaded in PDF from the following link:
http://www.cuisinart.com/share/pdf/manuals/dlc-2011n.pdf
Jan 04, 2012 | Cuisinart DLC-2011 PowerPrep Plus Food...
I have a Cuisinart DLC-8S TX Pro Custom 11 Cups Food Processor that I purchased in spring 2004 and used only sporadically. Last week, I burnt the motor by using it to make fondant. Big mistake. I take...
If you already have a lot of attachments for this model, I would purchase a used motor unit. I got a complete setup at a yard sale minus the work bowl cover for $3 as a spare, and often see them at thrift stores priced quite inexpensively. You could also check ebay. Motor units routinely go for less than $25 including shipping. I'm pretty sure most dcl-8 series motors will work with you bowl and attachments. I like the quality of the older units better than the newer ones. And if you watch ebay closely, you can pick up a lot of pieces really cheaply. Good Luck,
Marc
Oct 21, 2010 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-85 Pro Custom 11 Cups Food Processor. Checked motor as recommended, works fine. Put together as instructed, turned on and when I press the pulse button it turns it off. Help will be...
Whoops, when putting together I failed to insert the feeder cup.  When I did that it worked!  I should have more carefully followed the assembly instructions.  Thanks for your help.  What a great web site
Apr 17, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Machine on but not working
The video is generic, and may actually show a different model with completely different assembly instructions. For the DLC-8S and DFP-11 series, you want work bowl handle facing the front of the processor, feed tube on lid facing back of the processor, and sliding lock switch facing the front of the machine. For the DLC-2011, you want work bowl handle facing front, lid lined up with work bowl handle, and metal element hanging from pusher facing front.
To make sure the motor is working first, remove the work bowl, blade, etc. completely from the base of the food processor. Plug the base in and turn the food processor on. Then use a pen to press in the dark gray or black button on top of the processor - if it makes a sound, your motor is good. If it doesn't, call Cuisinart and get your processor repaired.
-Tha Mp3 Doctor
Mar 31, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Plastic bowl of Cuisinart DLC-7P will no longer lock in place
Buy replacement plastic bowl of Cuisinart DLC-7P is Cuisinart DLC-005AGTX-1 work bowl 14 cup.
Jul 15, 2008 | Cuisinart DLC-5 Food Processor
My food processor plastic container has never slipped on and off with ease i have to smash it into place and the double smash the handle to remove it from the base. I would like to get a new upper...
You can get a completely new work bowl set (not the original parts) from Cuisinart for around $118.00. You could also buy one from a shady eBay seller and see if the oldie works. I am a collector of these myself, but in reality, it is probably cheaper to get a new Cuisinart food processor - they are nearly as good as the old ones.
-Tha Mp3 Doctor
Jul 02, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart 11 cup processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Oct 13, 2007 | Cuisinart DLC-2011 PowerPrep Plus Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
751 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
