Question about LG LSC26905TT Side by Side Refrigerator
Ice maker stopped after electric shutoff
Greetings, Our LG fridge, model lsc26905tt was working fine last week when hurricane Ike shut off the power for 3 days. After electric returned (3 days ago) ice maker isn't working. No water is even getting to the tray. Maybe melted ice refroze after all the cubes ice melted?  Fridge was in house when we bought a few months ago so no manual. Thanks for any help. Mark
  • 1 more comment
  • qboy Oct 21, 2008
    I have an LG refrigerator. Recently, the icemaker will not dispense ice. It appears that no water is entering teh icemaker, although teh water dispenser in the door is working. My icemaker does not have a 'clear' button. The refrigerator is about 8 years old. Any deas?
  • JohnyBG Nov 17, 2008
    I have the same problem the fridge was off for a while and water/power was reconnected today, there is water ok in the water dispenser but the ice maker is not filling up. (from the posted solution earlier coul you please tell me which is the clear button?)
  • syndy_cave May 11, 2010
    LG fridge, model lsc26905tt Everything was working fine until about 2 weeks ago the water dispenser stopped and I notice no ice was being made either. The flap that close after dispensing ice stopped closing so I thought maybe it was freezing since there was ice forming on the back of the door where ice dispenses. I had not changed the filter so I did that still nothing, I unplugged the frdige for about 12 hours and took off water lines in back of fridge to the water soruce, no blockage from wall to fridge still no luck. HELP
  • 489 Answers
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
I am having a problem with the ice maker on my LG. We changed the filter in the last week and now it will not make ice. It was workking fine before this. We have tried everything, HELP!!!!!!
Maybe the filter is not installed correctly. Take it out and re-install it. I suppose the water valve is on. Of course, the fact that the ice maker is not working may be just coincidence. Put some water in the ice maker, wait some hours and see if it will push the ice out. If it does, that tells you that the ice maker does work. Let me know if you need more help.
May 26, 2011 | LG LSC26905TT Side by Side Refrigerator
Ice maker freezes up
It's likely you have your freezer to cold, Try reducing the setting on that. If that doesn't work you might wanna check your freezer and make sure it's not thawing and then freezing again, you might have a problem with your fridges thermostat.
Oct 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
My side by side is not making ice anymore?
Tania, if your unit is only 5 weeks old you should call an LG service co to repair in warranty. you shouldnt have I/M problems this early
Jan 21, 2009 | LG LSC26905TT Side by Side Refrigerator
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Dec 19, 2017 | Jenn-Air JCD2290HES Side by Side...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker trobleshooting
We lost power due to hurricane Ike and now that the power is back on the ice maker is not working. Is there a reset button or what needs to be done to get it working again?
Aug 10, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Ice maker is not getting water. motors appear to be working.
behind the fridge there is a service shut off valve. turn it on. This water line should go to a sink in the kitchen check there to
Jan 10, 2008 | LG LSC26905TT Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
875 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
