Question about Philips GoGear HDD075/17 MP3 Player
Philips gogear when i am swicthing my device on it shows only that .......problem connect to computer? when i am connecting to computer the device is getting all the songs showing in the removeable place i think it has lost main software has lost while i was down loading first time i formated the device.
  • 8,596 Answers
Get the latest verison of the Philips Device Manager for your model, and run the Repair function.
Posted on Mar 07, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
Error message File System Error
Whenever I go to turn on my Philips Gogear audio video mp3 player, it shows the welcome screen but it doesn't go to the GoGear or the updating screens. Also, whenever I plug it into my computer through the USB cord, the charging screen doesn't show and it does not show that it is connected on 'My Computer'
Aug 20, 2009 | Philips GoGear SA3125/37 MP3 Player
Doesn't show up when i plug it in to my laptop
To download music or photos on to your Philips GoGear, you need to use a computer that has Windows Media Player and Device Manager already installed. Once these are installed, the steps to sync your Philips GoGear Jukebox using Windows Media Player are fairly easy to follow. Follow these steps to sync your Philips GoGear.
Connect your Philips GoGear to the computer with the USB cable. The USB connector on the GoGear is on the top, and will be on the front or back of your computer. You will see a USB connection icon as soon as the GoGear is connected to the computer.
1.Start Windows Media Player from the Start Menu or from the desktop. To transfer files to your GoGear from your computer, click Copy to CD or Device (with WMP 9) or the Sync tab (with WMP 10). 2.Find the Items to Copy pane. In the drop-down list, click the category or playlist that you want to copy to your GoGear. Make sure that items that you do not want to copy are unchecked. 3.Locate the Items on Device pane. In the drop-down list, click GoGear. When you have selected the items that you want to sync, click the Copy (with WMP 9) or Start Sync (with WMP 10) button.
Apr 25, 2009 | Audio Players & Recorders
NOT'''' RESPONDING
Connect your mp3 player to the computer.
Open the Philips Device Manager
Run the Repair function.
If the Device Manager does not recognize the player, connect the player to the computer (while the player is in the OFF position) while holding in the volume + button. Continue holding the vol + button for 5-15 seconds until a window pops up on the computer screen that says Found New Hardware Wizard. Follow the directions and it will lead you to do a Repair in the Philips Device Manager.
If this strategy doesn't work, your player is screwed. Call Philips and find out how to get an in-warranty replacement (or take it back to the store).
-Tha Mp3 Doctor
Nov 16, 2008 | Philips GoGear SA178 MP3 Player
Frozen gogear
Try taking a something small(needle,pin)to poke the reset buttin if it has one.
Sep 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Connection to gogear
Sounds like the firmware is corrupt.
Try this:
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 27, 2008 | Philips GOGEAR SA6045 MP3 Player
It says its not connected
First, try installing the newr version of the software from the Philips website - www.usasupport.philips.com - enter your model number
If that fails:
Repair the device
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Feb 18, 2008 | Philips SA5125/37 MP3 Player
Philips HDD1630 MP3 Player about 2 years old, no excessive use, won't charge any more or be seen by computer. Only shows low battery on screen then dies. I am a little technically incline, can anyone tell...
You may have to change the battery, but try Reset, Repair, and Update (firmware upgrade) first. Also, there is an FAQ on the Philips website for the computer does not recognize device issue (but only follow it AFTER you have tried reset, repair, and update).
Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
After repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
Feb 05, 2008 | Philips HDD1630 MP3 Player
Will not charge
First, try uninstalling the software that came on the CD,and reinstalling the version of the software on The Philips website.
If that fails:
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Nov 15, 2007 | Philips GoGear HDD1830 MP3 Player
Philips GoGear HDD075/17 MP3 Player Logo
37 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
