Question about Magic Chef Kitchen Ranges
Hello, I have a a magic chief stove and its beeping every hour or so with the lettering of -4 L-. What does this mean?
    New Friend:
I have an older model magic chef I can't turn off the alarm ivevtriedeverything short of the sledge hammer ! How domi get to the mechanism to disconnect it?
Posted on Mar 08, 2015
Hit the SOB with a 12lb sledge like I did. Put out the alarm & then some! Id never own another Magic Chef product!
Posted on Sep 26, 2008
Magic Chef, F-1 code?
This might help... http://www.appliance411.com/archive/25036_magic_chef_f1_error_and_slow_to_heat.shtml
Jun 20, 2013 | Cooktops
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Hi have a " magic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jan 05, 2011 | Magic Chef CGS3760 Gas Kitchen Range
What does F1 mean when appearing in the digital display area accompanied by beeping? This is appearing repeatedly every few hours even when stove not in use.
Hello,this indicates a ERC/clock electronic range control fault.
Check or replace the touch pad or clock. The touch pad is a more common problem for this unit. Check for a stuck button by pressing each one and feeling for it retracting. This is easy to replace.
Thanks
Jun 10, 2010 | Magic Chef 9122 Gas Single Oven
I just got a used stove and its a single magic chef eletric stove. when I plug it up it will beep and on the display screen it says L1. what does that mean. im not sure what model it is though. its a older...
Usually L1 is a code for power on. So try to clear it by pushing enter or clear and see if it helps.
Please rate me accordingly if this helps and good luck.
Mar 13, 2009 | Magic Chef 9512 Electric Single Oven
Contune to beep F-1 flashes
f-1 codes are usually a temperature issue. you should try ohm'ing out the temperature probe you should have about 1260 ohms. if you are off by 40 ohms then replace the temperature probe. if it is close then you may have a bad control.
Dec 01, 2008 | Magic Chef Ovens
Replace the switch lighter for magic chief cook top
I would like to replace all gas head(4 sets) of the Magic Chief gas stove in Thailand. How to find the service center?
Aug 16, 2008 | Magic Chef 31000 Gas Kitchen Range
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Magic chef stove
F1 means the computer has corrupted....... Part is probably around $150-200 Please rate my help solved as I solved your question.
Oct 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Kitchen Ranges Logo
134 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
