SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
SOURCE: Door shelf support broken
Hi Shari. Yes. Go to any hardware store, or a home depot or lowes. Go to the adhesives isle. What you need is an epoxy adhesive that will work on plastic. There are different ones that will work so read info on the containers to find the appropriate one. One I use a lot with success is called JD WELD.
SOURCE: need door shelves for my samsung fridge -
Look at these two links to see if it's the same as yours.
http://www.partselect.com/ModelFrames.aspx?ModelID=195015&ModelNum=RS267LABP&mfgModelNum=&ManufactureID=1&Selected=58742&Position=11&mfg=Maytag&Type=&Mark=10
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS267LBBP&productCategoryId=0165000&brandId=1482&modelName=REFRIGERATOR&diagramPageId=00004&componentDescription=REFRIGERATOR%20DOOR&documentId=50033494&backToLink=Return%20to%20Sub%20Components%20list
