Question about Brother IntelliFAX 4100 Laser Fax
The machine says it has a paper jam
We cleared the paper jam but it still says it despite unplugging the machine, etc.
  • 97 Answers
Please check your sensor if they have dust or paper?
Clean your Sensor if working properly.
Posted on Sep 22, 2008
Our Canon jx210p fax keeps saying "chk printer
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
I cleared a paper jam in my hp officejet 7310xi/all-in-one and i'm still getting a carriage jam message. How can I get the printer back to normal?
Try to Reset your Printer.Before that search for any paper piece or any other obstacle which preventing carriage movement.
Full reset:
a. Unplug the power cable from printer when the printer is powered on.
b. Press and hold # and 6 while plugging in the power cord.
c. Wait until "Semi full reset" displays ("Semi" appears despite the fact this key sequence is defined as a full reset).
d. Answer questions - Language/country, etc.
Partial reset:
b. Press and hold # and 3 while plugging in the power cord.
c. Wait until "partial reset" displays.
I think it helps.
Jan 10, 2011 | HP OfficeJet 7310 All-In-One InkJet...
J01 error, but no paper jam; can't re-set
Remove the toner cartridge.
There should be 2 switch actuators sticking up from the base.
It sounds like one of these actuators has been knocked loose. Try to clip the actuator back on to the sensor.
This is a TOUGH job, you may need a sercive tech to look at it.
Oct 13, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Paper jam and still won't print
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Aug 15, 2009 | Brother Office Equipment & Supplies
I have had a paper jam
open the top lid and pull out the paper from the top
Feb 10, 2009 | Brother DCP 130C All-In-One InkJet Printer
I cannot clear paper jam message and shut off printer. I have no paper jam in the printer.
it would be helpful if you provide us with the brand and model af the printer. also, the message might be erased if you unplug it and leave it sit for an hour or two and then plug it in and try again.
hope this helps
Apr 09, 2008 | Office Equipment & Supplies
Brother IntelliFAX 4100 Laser Fax Logo
89 people viewed this question
James Cagle
James Cagle
Jim Keysor
