ERROR Window: Fail to read from dependant file.
Hi, I keep on getting this stubborn ERROR message: "Fail to Read from dependant file.This application will now close!" This is due to a Uniblue RegistryBooster2 Program. Please, can anyone help? I've tried registry fixing programs, but to no avail. Is there a registry setting, perhaps? I've also trief msconfig, but that also didn't work. I can try absolutely everythibg to close the error message, but it keeps on popping up on the desktop. Please, this is a URGENT CALL OUT. Thanks and looking forward to hearing from you, Heidi
  • Western Scrooby
    Western Scrooby Sep 19, 2008
    Thank you so much, but there is no icon in the system tray and also no registrybooster.exe entry in manager. I've tried this as well. Something else, maybe? Thanks again...
  • 61 Answers
If you are getting "Failed to read from dependent file" during installation, this is because Registry Booster is already running in the background.
If this is the case, then you should be able to see an icon in the
system tray next to the system clock. Double clicking on this icon should
restore the program window.
If you do not find it here, please right click on the taskbar and choose task
manager. In the processes tab you should find a registrybooster.exe entry. Select
it and click End Process.
Posted on Sep 19, 2008
I'm trying to install Gmail Talk and keep getting Error 1622
You may follow the steps given below and check if that helps to get rid of the error message while installation of application.
a) Click on Start
b) In the start Search box type Services
c) Right Click on"services" on top of the pop up and select Run as Administrator
d) Stop "Windows Installer" service.
e) Then, delete the temp folders; there may be a file in there interfering with the setup routine of the installer. Get both:
C:\Documents and Settings\<username>\local settings\temp
f) Finally, set your "Windows Installer" service's startup type to "Manual".
g) Reboot your system and have another test.
Hope this information is helpful.
Aug 16, 2012 | Google Talk
Yahoo messenger
Here is the solution to your concern. and below are the few steps:
- download this file sxtrace.exe
- click"Save File" & follow the simple installation instructions.
- click the "Repair" button to permanently fix sxstrace.exe error and other related errors.
If you still need my assistance you can reach me using this LINK .
Have a Good Day..
Feb 02, 2012 | Yahoo Messenger
I did a self test on my hp compaq nc6400 and got a read failure this my hard drive.does it need to be replaced
First thing, back up all of the files that you want to keep onto either an external drive/stick/disc etc as read failures relate to hard disc drive read/write errors within specific clusters or sectors. You may get away with replacing the drive for the moment but your best bet is to run CHKDSK which will require a reboot as its a DOS utility and then run disk defragmenter which can be found in the system tools folder within Windows Vista. This will take quite a long time depending on the size of the drive but it should find any damaged clusters/sectors and quarantine them so that the installed applications don't write any files to these areas. If the however the drive starts clicking and excessively whirring
Apr 12, 2011 | HP Laptop Keyboard for HP Compaq NC6400...
Ntvdm cpu encountered illegal operation Hi all! I just installed Maya 2010 from a torrent file and since then I got this famous error message. It's just appeears as three command prompts appearing at the...
If I am reading this right your issue is not the application but where you obtained the application. Maya 2010 is a modern design application and comes in 32 & 64 bit versions. It is not a 16 bit application.
When Windows encounters a legacy application it calls the NTVDM for the legacy application to run in.
The fact that the application is calling the NTVDM is highly suspicious. NTVDM is the NT Virtual Dos Machine, a way for legacy applications to run in NT environments.
NT environments are Windows NT 3.5, NT 4.0, Windows 2000 Professional, Windows XP (Home, Pro & Media Center Ed), Vista (all versions) and Windows 7.
Old (legacy) applications written for 16 bit date back to Windows 3.1 and include Windows 95, 98 and Millennium Edition.
I would obtain a copy of Maya 2010 from a reputable outlet instead of Bit Torrent as "warez" frequently contain malicious items that will infect and ruin your machine.
Feb 05, 2010 | Microsoft Windows XP Home Edition
Wf2k.exe - unable to locate component
Download tis file from then paste in C://windows/system32 then try.
Dec 03, 2009 | Computers & Internet
I recently had a HD crash and have replaced it with another HD using the same Windows XP OS. While trying to reload programs that were on the old HD to the replacement, some of the programs get this error...
I always receive a "C:\WINDOWS\SYSTEM32\AUTOEXEC.NT" error message.
“C:\WINDOWS\SYSTEM32\AUTOEXEC.NT. The system file is not suitable for running MS-
DOS and Microsoft Windows applications. Choose ‘Close’ to terminate the application.”
This error message is not caused by the installation CD-ROM, but rather by the
“Autoexec.nt” system file. Windows is unable to find this file when launching the
installation CD-ROM, the file most likely having been deleted by another application.
To resolve this problem, proceed as follows:
1. Go to “C:\Windows\repair” and find the file “Autoexec.nt”.
2.Copy this file to “C:\Windows\system32”.
3.Right-click the file “Autoexec.nt” that you have just copied, and select
4.Tick the “Read-only” box and then click “OK”.
Aug 06, 2009 | Microsoft Windows XP Professional SP2 Full...
Odd application failure... missing assembly?
Do you have the Visual C++ 2005 Redistributable installed? The "Dependent Assembly..." error indicates that you do not have it installed yet. You can download it at the link below. Please report back with your results.
Mar 23, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
346 people viewed this question
David Payne
David Payne
