Onkyo DV-CP701 Multi-disc DVD Player Logo
Anonymous Posted on Sep 30, 2011
Error message mechr err-can't open unit - Onkyo DV-CP701 Multi-disc DVD Player
My canon ds6041 displays err 99 when i try to capture light aur object in sun light.What should i do i'm using 70-21-mm lense
Usually this is cased by shutter failure or failure of the aperture unit in the lens. Try another lens and see if you get the same error message - that will tell you if the problem is in the camera body or lens
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
I am recieving a error 1 message on my Canon RebelXT/Eos
ERR 01 is a lens communication error. Try cleaning the contacts on the lens and in the mirror box.
ERR 05 is a flash error. It is usually caused because the flash failed to pop up. This can be casued by something as simple as the flash hitting the brim of a 'gimme' cap or impact to the flash or most likely spillage of sticky liquid around the flash and its pivots.
The XT also is notorious for having the bottom right screw of the rear circuit board come loose and short out some function of the camera, or even blow the main fuse or damage the circuit boards.
I'm getting a error message that says, "ERR 99".
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sony BDP-BX2 blu-ray disk player "SYS ERR" error message
This worked for me, from a Sony Tech.
1) When SYS ERR is displayed turn off the player by holding down the power button until tghe unit turns off. 2) Unplug the power cord. 3) Wait a minute or so and plug the player back in. This reset the player for me.
Err message appears when CD function is used
check this link for service manual
Don't forget to rate the solution
3helpful
Cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
2helpful
3answers
PH SIG ERR: 39:02:
phone sig error mean your Phone MonsterPack(software) is demaged. you need to flash back using RSD lite to make back to normal. give me what software version you have on your cell and what bootloader you have..eg.bootloader 0A.30/0A.52..SW:R479 and etc. i these so i can upload one for you
Top Onkyo Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
